Speedo Meter Reading
From Sri Lanka
HI Guys
the Arrowed Speedo Meter doesn't work in my dash, but the lower meter is working fine , what is the reason is it something with electrical or what ?
Thanks
Regards
Sumith
jpg  speedo.JPG (16.43 KB)
10994_4c037977ccd29.jpg 352X288 px
Posted on: 2010/5/31 9:55
Re: Speedo Meter Reading
If the odometer works, then the cable must be turning the gauge.
In this case but the speedometer needle doesn't move, something in the gauge itself is broken of jammed. Replace the entire speedometer with another.
Posted on: 2010/5/31 18:23
From Sri Lanka
Hi DD
No No ,Speedo Needle works as well as down ODO meter also working but not the up ODO meter that i have put an arrow
towards.
Thanks
Regards
sumith
Posted on: 2010/6/1 4:19
One is the odometer
The other is the "trip meter"
You have to push the knob in, or turn it, to reset the trip meter. It is not uncommon for them to break.
Posted on: 2010/6/1 5:33
From Sri Lanka
HI DD
Yes Trip Meter the nob is stuck inside , you can't press it,it was working till last month but not now.can i reset it manually removing the dash cover ?
Thanks
Regards
sumith
Posted on: 2010/6/1 5:56
