Re: Tire height
From Las Vegas USA
Eric I did this on my Mazda; I went a slighter better ride and went to a taller profile tire and in the process dropped a little less than 100 RPM's which in my case got the motor out of an RPM band where it was rather boomy.
Look online there are final drive/speed RPM calculators all over the internet you can plug in tires sizes and see what size you'll need for a given RPM. The ultimate method of course is a 5 speed overdrive, you can lower the rear gear to 4:11 for acceleration and the overdrive will drop the revs..........but in the meantime play with the numbers online.
Now keep in mind an A-series engine will run at 5500 RPMs or more all day long..........if it is a case of engine noise inside the car but some insulation material / Thermal barrier materials made for cars. I think Thermo-Tec is a brand of insulation. Again the motor doesn't care and the gas milage is fine with stock gearing but interior noise on our cars is an issue.
Tom
Posted on: 2010/7/8 2:24
Subject Poster Date
     Tire height ericsb210 2010/7/7 19:10
       Re: Tire height Rallytwit 2010/7/8 2:24
         Re: Tire height ddgonzal 2010/7/8 2:27
           Re: Tire height Kiri1 2010/7/8 7:46
       Re: Tire height baldy 2010/7/8 9:15
       Re: Tire height ericsb210 2010/7/8 17:22
       Re: Tire height ericsb210 2010/7/8 17:57
         Re: Tire height ddgonzal 2010/7/8 19:25
           Re: Tire height ericsb210 2010/7/8 21:05
             Re: Tire height ddgonzal 2010/7/8 21:27
               Re: Tire height Rallytwit 2010/7/9 4:58
       Re: Tire height ericsb210 2010/7/9 18:26
