Bottom Leaf spring
I am in need of the bottom leaf from the springs from a 1200 ute or the measurements for them so i can get new ones made.Thickness and length would be good. thanks
Posted on: 2010/7/27 11:04
Re: Bottom Leaf spring
From Geelong, Vic
the load leaf?
Posted on: 2010/7/27 11:12
Not sure if it is the load leaf,but it is the smallest one
Posted on: 2010/7/27 11:41
From Geelong, Vic
is it the really thick flat one?
Posted on: 2010/7/27 12:07
From Melbourne AUS
where are you located leroy,
ill have some spares you can have very soon
Posted on: 2010/7/27 13:03
1973 B110 A12
I am in Sydney,just the measurements would be appreciated
Posted on: 2010/7/27 22:22
Can anyone help me with this?
Posted on: 2010/8/2 7:42
From Melbourne AUS
the thickness varies from the middle to the edges of the leaf,
and the width of the leaf is wider at the ends than it is in the middle.
also the leaf isnt bolted to the others in the middle, there is more leaf forward of the axle or vice versa (cant remember which)
if you like i can do a bit of a drawing for you with some more accurate measurements
but i do have spares here in melbourne if its easier for you than getting some made?
Posted on: 2010/8/2 7:56
1973 B110 A12
Do you have the 5-pack or 7-pack ute leafs?
You really don't need the bottom (smallest) leaf unless you are hauling cargo in the back. It rides smoother without it, but also will sit a bit lower.
Posted on: 2010/8/2 8:46
