Anyone in Brisbane running 120Y brakes?
From brisbane
I would like to see if my 10" wheels will fit over the later model 120Y brakes with the PBR calipers.
Anyone able to help me out?
Thanks Matty
Posted on: 2010/10/3 8:31
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Re: Anyone in Brisbane running 120Y brakes?
From Rosewood, QLD
i have those girlock calipers i think they are from 120y but i dont think that will help you lol
Posted on: 2010/10/3 9:34
1971 B110 sedan project.
2012 Nissan Micra daily.
i don't think they will. even the stock 1200 wheels don't fit. i had to use the 120y 12 inch rims.
Posted on: 2010/10/3 11:15
From Melbourne AUS
hmm, ive got 120y pbrs on my sedan with standard 12" wheels.
unless theyre not 1200 wheels?
Posted on: 2010/10/3 11:19
1973 B110 A12
sorry i'm talking stock 1200 sedan rims. utes have the same as 120y.
Posted on: 2010/10/3 11:24
From Melbourne AUS
ok, well maybe my sedan came with ute/120y wheels when i bought it.
Posted on: 2010/10/3 11:29
1973 B110 A12
that is common.
Posted on: 2010/10/3 11:37
From brisbane
Thanks for the replies everyone.
I have trial fitted both 1200 coupe and early 120Y set ups and they fit fine. I would just prefer to use the slightly bigger set up from a later 120Y if they fit.
Is there any difference, other than cosmetic, between 1200 coupe and early 120Y front disc brakes?
Thanks again Matty
Posted on: 2010/10/3 12:21
Not to sure on the differance between coupe and 120y early. the late 120y pbr are a taller caliper.
we will find out soon. just come up when your ready.
Posted on: 2010/10/3 22:52
From sydney australia
The main difference is the diameter of the outside of the outer wheel bearing area on the hub, with the PBR it's bigger. The later 120Y wheels had a bigger centre hole to allow for this. Strangely I've had 13" wheels that wouldn't fit over 1200 discs & 12" wheels that wouldn't fit the PBRs.
Thats why I ended up going to 14's.
Posted on: 2010/10/4 0:18
