« 1 ... 3 4 5 (6) 7 8 9 ... 12 »
#51 Re: Fergus, the daily dunga!
Shoota_77 Posted on: 2011/8/3 13:28
Decided to risk getting the A14 in before the cruise. Cheated and used the hoist in the workshop after work tonight. Makes things a bit easier!
I got some wank factor "halo" LED ring headlights. Should be a subtle little improvememt-
Otomoto coilover kit rocked up today so provided I can get the engine back in I should be able to get my struts sorted and hopefully convince my 17's that they fit on the front!
Gunna be pushing to get it back on the road before next weekend...
#52 Re: Fergus, the daily dunga!
Posted on: 2011/8/3 13:33
Lucky it's a light car- push smarter not harder
#53 Re: Fergus, the daily dunga!
lamb_daiquiri Posted on: 2011/8/3 14:22
You got more done than I did tonight! Made two brackets that didn't fit..... Always the fiddly things. Thanks for the struts.
#54 Re: Fergus, the daily dunga!
RSR100 Posted on: 2011/8/3 14:33
looking good shoota.
hoist makes your life a whole lot easier.
let me know how the struts come up!
cheers rob
#55 Re: Fergus, the daily dunga!
cadet1200 Posted on: 2011/8/3 14:58
I'm also interested to see how you go fitting the coilovers...although if I fit some up I'll wait till after the engineer signs off.
How much were the halo lights?
P.S. I reckon you need to fit a higher profile rear tyre to fill it out a bit more.
#56 Re: Fergus, the daily dunga!
Shoota_77 Posted on: 2011/8/3 21:46
Mik- ???? I'm big and can lift heavy things. Puzzles aren't my strong point!!
Dylan- no dramas mate. I hope they're useful for you. Good luck with the throttle body plans, sounds like it should be pretty awesome once done.
Rob- when you're 6'8" the hoist is awesome just to have the car elevated to work under the bonnet, saves my back a bit!
Andrew- the halo lights were bloody cheap! About $60 delivered from USA. With the tyres, you might be right but see how it comes up once i put the coilovers in and play with ride height a bit. Once they're up in the guards they won't look too small!
#57 Re: Fergus, the daily dunga!
Posted on: 2011/8/3 22:07
I thought everything looked small from up there?
Get that a14 in the hole, the hole is your home
#58 Re: Fergus, the daily dunga!
Shoota_77 Posted on: 2011/8/4 13:05
Getting there. Not gnnna be pretty (not painted or even cleaned!) but going for function over form! I can clean it all up later.
Should hopefully finish by tomorrow night. Then off to exhaust shop to get new exhaust. Probably go for 2.5" I guess. Extractors finish at 2.25".
#59 Re: Fergus, the daily dunga!
Posted on: 2011/8/4 13:53
2 or 2.25 is way big enough for a 14. 2 inch is enough. 2.5 going to be noisy. I SAID IT WILL BE LOUD O K?
#60 Re: Fergus, the daily dunga!
1200rallycar Posted on: 2011/8/4 15:03
they need some back pressure, 2 inch is the widely reccomended size
