Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
How to repair loose bonnet frame?
ronald_loulan
Posted on: 2012/1/30 2:10
My bonnet frame came loose..
It will rattle during low idle speed... Any idea how to do it the right way?? Thanks
#2
Re: How to repair loose bonnet frame?
Posted on: 2012/1/30 2:38
It was glued on by the factory. Use a seam sealer to repair it is the 'correct' way.
I wonder if a modern 2-part body epoxy would work?
#3
ronald_loulan
Posted on: 2012/1/30 2:51
Will the epoxy u mention a bit hard for the hood??
It will dent the hood if it is too hard, right??
#4
bailz
Posted on: 2012/1/30 2:56
Use a seam sealer or panel adhesive... Check out upol website... U can get adhesives that set off in a few minutes or up to 60mins... Don't use a 2pack epoxy resin it wont fill the gap between the panels
#6
srb210
Posted on: 2012/1/30 12:38
Agreed with Dundee , in black or white and can be painted over
#7
edp
Posted on: 2012/1/30 22:42
I used this Evercoat product but I wondered if one could get away with a standard urethane product like Sikaflex. The Maxim is a 2 part epoxy & paints just fine but its hard to get. The advantage of this over the 3M seam sealer was the tube, its a single cartridge to fit a standard caulking gun. The others (3M sausage tubes & other 2 part epoxy's) require special guns. It cures to a very solid state unlike conventional urethane which tends to stay flexible throughout its life.
http://www.evercoat.com/productCategory.aspx?cat=41 Dundee & srb210 - have both of you guys used single part urethane for that purpose before with success?
#8
Dundee1000
Posted on: 2012/1/31 0:23
used it many times, awesome stuff.. used it to brace panels, stops drumming, (ie tin over a steel frame)
#9
ronald_loulan
Posted on: 2012/1/31 1:39
Ohh ya...
I heard about the sikaflex thing b4... Thanks guys...
#10
ronald_loulan
Posted on: 2012/2/3 7:02
Will Sikaflex 255 Extra corrode the bonnet??
