180B Struts with new slotted rotors and calipers - swap for 120y standard
Quite a regular
as it says i have a pair of 180b struts with new shock inserts, new king springs and slotted dba rotors and new pads and caliper kits through them, im wanting to swap them for a set of good condition standard 120y struts to back in my car.
cheers
Posted on: 2012/4/11 0:06
Re: 180B Struts with new slotted rotors and calipers - swap for 120y standard
From Sydney
how much do u wanna sell them for?? pm me
Posted on: 2012/4/11 2:52
From mandurah
Will 200b brakes go onto the 180b struts ?
Ive got a set of late model 120y struts and brakes ,new pads and rotors fitted and chopped king springs ( later model had bigger brakes and better one calipers)
I bought 200b struts with coilovers and now i found out one is bent pretty bad that's why I wanna know if the the 180 strut is the same as a 200b strut cos they have better brakes
Posted on: 2012/4/11 3:16
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Some are pending on bolt spacing, but kpi and hub offset is different! You'd need to measure these! Aus and Jap models had differant stuff!
Girlock, pbr ect
Posted on: 2012/4/11 3:45
Car free
Quite a regular
i will take photos tonight of my set up so we can try and figure out whats in there
Posted on: 2012/4/11 4:32
