Re: Wanted 1200 diff
From Geelong, Vic
what year is the ute?
if its an early one, i think 71-74/75 then it will have the smaller diff in it (same as other 1200 diffs) in which case the bluebird centre will not work
if its the later one, 75 onwards then a 4 door 4 speed series 1 bluebird should have the centre you are after. otherwise other series 1 and 2 bluebirds and jap assembled stanzas will have 3.9:1 ratio diffs that will do the job
Posted on: 2012/10/1 4:05
Subject Poster Date
     Wanted 1200 diff murray62 2012/9/30 0:57
       Re: Wanted 1200 diff Stock1200Ute1 2012/9/30 2:03
       Re: Wanted 1200 diff PIGDOG 2012/10/1 4:05
         Re: Wanted 1200 diff 1200rallycar 2012/10/1 4:17
       Re: Wanted 1200 diff DatsAndy 2012/10/1 7:06
         Re: Wanted 1200 diff Stock1200Ute1 2012/10/1 8:49
           Re: Wanted 1200 diff Stock1200Ute1 2012/10/1 8:50
       Re: Wanted 1200 diff murray62 2012/10/2 13:15
         Re: Wanted 1200 diff BigD 2012/10/3 1:00
           Re: Wanted 1200 diff Stock1200Ute1 2012/10/3 2:56
       Re: Wanted 1200 diff murray62 2012/10/4 11:57
       Re: Wanted 1200 diff StanzaSSS 2012/10/11 4:10
       Re: Wanted 1200 diff jmac 2012/10/11 8:55
       Re: Wanted 1200 diff nickmitty 2012/10/11 9:30
       Re: Wanted 1200 diff murray62 2012/10/14 11:44
