Re: SR20DET into 1200 Coupe Project
From Little Rock, AR
Well today I finally got to go and size the SR20 into the 1200. It actually dropped in pretty easy, I took the sway bar out to make things a little easier, although the engine just barely fits inside the aftermarket 7/8" thick sway bar. The GREAT news is that I can use the stock turbo location and outlet pipe!!! I was a little worried about it all hitting the steering box on a LHD car, but it clears fine with plenty of room!!! Now I won't need the top mount manifold and all that other crap! This is going to make things SOOO much easier!!!
There is one problem though, the Greddy style intake is a lot longer than the stock one, so there isn't much room between the throttle body and radiator. The engine can still go back another inch or two so we'll see if I can get enough room in there to fit the intake, otherwise I'll be stuck using the stock one.
Anyway, I'm leaving for Thailand tomorrow, so I won't be able to do anything on it for 2 weeks, but I've posted all the pictures that people have been dying to see to show everyone how much clearance you have to work with when putting the SR20DET into an originally automatic 72 1200 Coupe. Here's links to the pictures!!!
Suspension Height with SR20
Oil Pan clearance
Steering box/turbo
Steering box/turbo
Left side of the engine bay
Outlet pipe location
Outlet pipe exit location
Rear engine shot
Front engine clearance
Rear engine clearance
Engine mount Left side
Large view of engine
Zoomed out view of engine
Posted on: 2004/5/15 9:42
Subject Poster Date
     SR20DET into 1200 Coupe Project AFRacer 2004/2/25 15:45
       Re: Finally my SR20 project is on it's way! matbighat 2004/2/25 17:20
         Re: Finally my SR20 project is on it's way! Astro_Boy 2004/2/25 22:26
           Re: Finally my SR20 project is on it's way! AFRacer 2004/3/12 12:03
             Re: Finally my SR20 project is on it's way! AFRacer 2004/3/17 9:44
               Re: Finally my SR20 project is on it's way! AFRacer 2004/3/22 14:13
                 Re: Finally my SR20 project is on it's way! muke 2004/3/22 14:42
                   Re: Finally my SR20 project is on it's way! Team_Dat 2004/3/23 1:19
                     Re: Finally my SR20 project is on it's way! 1200rallycar 2004/3/23 9:57
                       Re: Finally my SR20 project is on it's way! AFRacer 2004/3/23 14:07
                         Re: Finally my SR20 project is on it's way! 1200rallycar 2004/3/23 14:24
                           Re: Finally my SR20 project is on it's way! AFRacer 2004/5/2 5:18
                             Re: Finally my SR20 project is on it's way! AFRacer 2004/5/4 12:57
                               Re: Finally my SR20 project is on it's way! AFRacer 2004/5/8 10:06
                                 Re: Finally my SR20 project is on it's way! AFRacer 2004/5/9 14:51
       Re: SR20DET into 1200 Coupe Project AFRacer 2004/5/11 12:24
         Re: SR20DET into 1200 Coupe Project AFRacer 2004/5/15 9:42
           Re: SR20DET into 1200 Coupe Project dattodevil 2004/5/15 10:01
             Re: SR20DET into 1200 Coupe Project ang94541 2004/5/15 19:29
               Re: SR20DET into 1200 Coupe Project AFRacer 2004/5/15 23:01
                 Re: SR20DET into 1200 Coupe Project AFRacer 2004/5/30 8:53
                   Re: SR20DET into 1200 Coupe Project belgian_roadster 2004/5/30 17:39
                     Re: SR20DET into 1200 Coupe Project matbighat 2004/5/31 1:01
                     Re: SR20DET into 1200 Coupe Project AFRacer 2004/6/1 15:30
                       Re: SR20DET into 1200 Coupe Project matbighat 2004/6/1 18:17
                         Re: SR20DET into 1200 Coupe Project belgian_roadster 2004/6/3 19:58
                           Re: SR20DET into 1200 Coupe Project AFRacer 2004/6/7 2:28
                 Re: SR20DET into 1200 Coupe Project mperdue 2004/9/20 19:22
                   Re: SR20DET into 1200 Coupe Project AFRacer 2004/9/23 14:08
                     Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/1 16:28
                       Re: SR20DET into 1200 Coupe Project 2332owner 2004/10/1 17:50
                         Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/2 6:22
                           Re: SR20DET into 1200 Coupe Project 2332owner 2004/10/2 9:21
                             Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/2 10:26
                               Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/2 10:52
                                 Re: SR20DET into 1200 Coupe Project ca18det_man 2004/10/2 11:32
                                   Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/2 13:51
                                 Re: SR20DET into 1200 Coupe Project ddgonzal 2004/10/3 3:56
                                   Re: SR20DET into 1200 Coupe Project 1200rallycar 2004/10/3 5:31
                                     Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/4 9:03
                                       Re: SR20DET into 1200 Coupe Project ca18det_man 2004/10/6 12:50
                                         Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/17 12:20
                                           Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/23 3:25
                                             Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/31 12:47
                                               Re: SR20DET into 1200 Coupe Project woodydat 2004/10/31 13:18
                                                 Re: SR20DET into 1200 Coupe Project AFRacer 2004/10/31 22:02
                                                   Re: SR20DET into 1200 Coupe Project AFRacer 2004/11/7 1:53
                                                     Re: SR20DET into 1200 Coupe Project dattodude 2004/11/7 3:06
                                                       Re: SR20DET into 1200 Coupe Project phunkdoktaspok 2004/11/7 4:49
                                                         Re: SR20DET into 1200 Coupe Project AFRacer 2004/11/7 13:34
                                                           Re: SR20DET into 1200 Coupe Project AFRacer 2004/11/13 9:39
                                                             Re: SR20DET into 1200 Coupe Project AFRacer 2004/11/14 9:52
                                                               Re: SR20DET into 1200 Coupe Project ddgonzal 2004/11/14 21:13
        Re: SR20DET into 1200 Coupe Project AFRacer 2004/12/16 11:07
        Re: SR20DET into 1200 Coupe Project AFRacer 2004/12/20 9:52
        Re: SR20DET into 1200 Coupe Project 2332owner 2004/12/20 10:15
        Re: SR20DET into 1200 Coupe Project 2332owner 2004/12/20 13:19
        Re: SR20DET into 1200 Coupe Project AFRacer 2004/12/21 1:31
        Re: SR20DET into 1200 Coupe Project 2332owner 2004/12/21 11:34
        Re: SR20DET into 1200 Coupe Project kegs 2004/12/21 19:59
        Re: SR20DET into 1200 Coupe Project 2332owner 2004/12/22 0:19
        Re: SR20DET into 1200 Coupe Project AFRacer 2004/12/22 1:36
        Re: SR20DET into 1200 Coupe Project aleks 2004/12/22 4:10
        Re: SR20DET into 1200 Coupe Project datsuncr 2004/12/22 19:19
        Re: SR20DET into 1200 Coupe Project AFRacer 2005/1/2 23:36
        Re: SR20DET into 1200 Coupe Project BACKFIRE 2005/1/3 0:10
        hello anser 2005/4/1 1:17
        Re: hello NIS15L 2005/4/1 2:00
        Re: hello LAGWAGON 2005/4/1 2:06
        Re: hello dattodevil 2005/4/1 8:03
        Re: hello tom210 2005/4/1 10:12
        Re: hello Demojob 2005/4/1 12:49
        Re: engine mounts Puls8r 2005/4/1 13:18
        Re: engine mounts dattodevil 2005/4/1 13:29
        Front suspension brakes Puls8r 2005/4/1 13:52
        Re: Front suspension brakes 2332owner 2005/4/1 14:04
        Re: Front suspension brakes AFRacer 2005/4/14 12:50
        Re: Front suspension brakes AFRacer 2005/4/17 13:38
        Re: Front suspension brakes LAGWAGON 2005/4/17 15:02
        Cost? AFRacer 2005/4/17 15:26
        Re: Cost? dattodude 2005/4/17 22:43
        Driving impressions AFRacer 2005/4/21 14:51
        Re: Driving impressions AFRacer 2005/4/21 15:18
        Re: Driving impressions Quicksand 2005/4/21 19:09
        Re: Driving impressions AFRacer 2005/4/23 19:18
        Re: Driving impressions dattodude 2005/4/24 0:29
        SR20DET into 1200 Coupe Project AFRacer 2005/4/24 12:57
        Re: SR20DET into 1200 Coupe Project dattodude 2005/4/24 13:50
        Re: SR20DET into 1200 Coupe Project AFRacer 2005/4/26 4:55
        Re: SR20DET into 1200 Coupe Project LAGWAGON 2005/4/26 5:34
        Re: SR20DET into 1200 Coupe Project B120dat 2005/4/26 7:22
        Re: SR20DET into 1200 Coupe Project datrat_dave 2005/4/26 9:04
        Re: SR20DET into 1200 Coupe Project AFRacer 2005/4/26 9:34
        Re: SR20DET into 1200 Coupe Project Demojob 2005/4/26 12:38
        Re: SR20DET into 1200 Coupe Project converted 2005/4/26 12:51
        Re: SR20DET into 1200 Coupe Project AFRacer 2005/4/26 13:53
        Re: SR20DET into 1200 Coupe Project converted 2005/4/26 13:58
        Re: SR20DET into 1200 Coupe Project 2332owner 2005/4/26 16:25
                                                       hello anser 2005/4/1 1:15
                           Re: SR20DET into 1200 Coupe Project tom210 2005/4/4 8:34
       Re: SR20DET into 1200 Coupe Project AFRacer 2004/6/1 14:19
       Re: SR20DET into 1200 Coupe Project AFRacer 2004/6/13 9:10
       Re: SR20DET into 1200 Coupe Project mad120y 2004/6/16 9:23
         Re: SR20DET into 1200 Coupe Project converted 2004/6/16 9:36
           Re: SR20DET into 1200 Coupe Project AFRacer 2004/6/19 6:22
             Re: SR20DET into 1200 Coupe Project AFRacer 2004/7/23 1:22
               Re: SR20DET into 1200 Coupe Project ang94541 2004/7/23 7:55
                 Re: SR20DET into 1200 Coupe Project AFRacer 2004/8/11 6:06
                   Re: SR20DET into 1200 Coupe Project AFRacer 2004/9/20 16:35
       Re: SR20DET into 1200 Coupe Project AFRacer 2005/4/27 16:57
         Re: SR20DET into 1200 Coupe Project killer1200 2005/4/27 17:20
           Re: SR20DET into 1200 Coupe Project AFRacer 2005/4/28 14:22
             Re: SR20DET into 1200 Coupe Project AFRacer 2005/4/30 15:40
               Re: SR20DET into 1200 Coupe Project AFRacer 2005/5/8 15:19
                 Re: SR20DET into 1200 Coupe Project datrat_dave 2005/5/9 12:54
                   Re: SR20DET into 1200 Coupe Project dattodude 2005/5/9 22:54
                     Re: SR20DET into 1200 Coupe Project datrat_dave 2005/5/10 13:52
               Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/5/27 6:10
                 Re: SR20DET into 1200 Coupe Project AFRacer 2005/5/27 17:19
                   Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/5/28 3:59
                     Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/5/28 4:28
                       Re: SR20DET into 1200 Coupe Project AFRacer 2005/5/28 16:06
                         Re: SR20DET into 1200 Coupe Project AFRacer 2005/5/28 16:32
                           Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/5/28 17:59
                             Re: SR20DET into 1200 Coupe Project AFRacer 2005/5/29 4:36
                               Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/6/3 6:02
                                 Re: SR20DET into 1200 Coupe Project 1200rallycar 2005/6/3 8:25
                                 Re: SR20DET into 1200 Coupe Project phunkdoktaspok 2005/6/3 8:54
                                   Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/6/4 4:27
                                 Re: SR20DET into 1200 Coupe Project AFRacer 2005/6/3 9:55
                                   Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/6/4 4:24
                                     Re: SR20DET into 1200 Coupe Project AFRacer 2005/6/6 16:34
                                       Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/6/6 19:32
                                         Re: SR20DET into 1200 Coupe Project AFRacer 2005/6/7 17:02
                                           Re: SR20DET into 1200 Coupe Project converted 2005/6/8 2:14
                                             Re: SR20DET into 1200 Coupe Project twistex 2005/7/4 10:19
                                               Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/7/6 3:37
                                                 Re: SR20DET into 1200 Coupe Project twistex 2005/7/6 7:25
                                                   Re: SR20DET into 1200 Coupe Project AFRacer 2005/7/22 2:26
                                                     Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/7/25 2:04
                                                       Re: SR20DET into 1200 Coupe Project AFRacer 2005/7/27 22:18
                                                         Re: SR20DET into 1200 Coupe Project MRSR1200 2005/7/31 12:20
                                                           Re: SR20DET into 1200 Coupe Project converted 2005/7/31 12:29
                                                           Re: SR20DET into 1200 Coupe Project b310gx 2005/8/1 2:21
                                                             Re: SR20DET into 1200 Coupe Project tappet 2005/8/1 3:55
                                                               Re: SR20DET into 1200 Coupe Project MRSR1200 2005/8/1 5:50
                                                           Re: SR20DET into 1200 Coupe Project prodat 2005/9/16 7:56
                                                             Re: SR20DET into 1200 Coupe Project dattodude 2007/5/6 22:29
                                                         Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/8/2 5:33
                                                           Re: SR20DET into 1200 Coupe Project AFRacer 2005/9/15 10:08
                                                             Re: SR20DET into 1200 Coupe Project liam_1200_coupe_deluxe 2007/5/8 1:50
                                                               Re: SR20DET into 1200 Coupe Project converted 2007/5/8 2:26
        Re: SR20DET into 1200 Coupe Project tappet 2007/5/8 12:01
                                                               Re: SR20DET into 1200 Coupe Project 1200post 2007/5/19 13:06
        Re: SR20DET into 1200 Coupe Project Mildman 2007/5/19 13:26
                                           Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/7/6 3:27
                         Re: SR20DET into 1200 Coupe Project tens_and_twenties 2005/5/28 17:50
       Re: SR20DET into 1200 Coupe Project AFRacer 2009/4/12 0:02
         Re: SR20DET into 1200 Coupe Project dattodude 2009/4/12 0:20
           Re: SR20DET into 1200 Coupe Project datsa73 2009/4/12 16:50
