(1) 2 3 4 »
L16 twin su into a15
dear all...
i just bought L16 twin SU carb c/w air-cleaner box. for around USD 50. it was unused for 2 year/ need full service.
my question is what to do to fit it to a15 engine...?
pls help...
jpg  WP_20140531_009.jpg (183.65 KB)
17554_539329df237d3.jpg 414X737 px
Posted on: 2014/6/7 15:56
Re: L16 twin su into a15
From Malaysia
you need to make the manifold.
Posted on: 2014/6/7 17:15
The carbs will work as-is
The manifold you need depends on which A15 you have.
* for standard oval port head, use the factory A14T manifold
* for standard round port head, use an aftermarket twin SU manifold
Intake Manifold
Posted on: 2014/6/7 20:22
You will also need a different air filter as the spacing between l16 and a15 mounting is different.
also need the connecting rod between the sus with the stoppers as this is different too.
Not bolt on. You may also find it a bit rich in the tuning but a decent upgrade
Posted on: 2014/6/8 2:47
many many thanks for the replies....
a15 twin su manifold is very hard to get here. almost not available. so i need to custom made the manifold...
possible to mod the L16 manifold with a15 flange ???
Posted on: 2014/6/9 6:20
Yes its possible.
No company makes a15 twin su manifold. So we use an A14 manifold, since all A15 use A14 heads.
Posted on: 2014/6/9 23:56
its very rare as well.
here in malaysia, can get twin su carb and manifold for L series engine. but not for a series..
im searching for it for past few weeks all over the malaysia.. but bad luck. even got also no one willing to sell...
Posted on: 2014/6/13 13:49
is there anyone successfully done this mod? L16+a15 manifold.
can share some idea and pictures...???
thanks.
Posted on: 2014/6/13 13:50
hey mate
very close mate of mine used to make custom manifolds out of steel to fit 180b sss twin sus into a series for rally.
so its definitely possible.
Posted on: 2014/6/13 13:55
I think no one has converted L-series manifold to use on A-series. So you will be the first.
Posted on: 2014/6/13 21:26
(1) 2 3 4 »
