« 1 2 3 4 (5) 6 7 »
#41 Re: States 1200 Coupe. (Oregon, US)
Mattndew76 Posted on: 2015/6/5 21:53
That's a cool setup. Gives me the how to all in one place.
Good thing because I was about to Craig's List this one and save for the Winters swap instead.
#42 Re: States 1200 Coupe. (Oregon, US)
ddgonzal Posted on: 2015/6/5 22:47
If you go to pick-ln-pull and get two ranger short-side axles you can shorten it to that.
#43 Re: States 1200 Coupe. (Oregon, US)
Mattndew76 Posted on: 2015/6/5 23:56
I'm unfamiliar with the term short side. Is that for straight axle front end?
#44 Re: States 1200 Coupe. (Oregon, US)
ddgonzal Posted on: 2015/6/6 0:22
Ford Ranger 8.8 rear has an offset diff. One axle is long, one is shorter. See Rear Axle Swaps
#45 Re: States 1200 Coupe. (Oregon, US)
Mattndew76 Posted on: 2015/6/6 20:44
Using the short side shaft will put the axle at the right width for the 1200?
#46 Re: States 1200 Coupe. (Oregon, US)
Mattndew76 Posted on: 2015/6/6 20:57
Gotta have these welded.
#47 Re: States 1200 Coupe. (Oregon, US)
Mattndew76 Posted on: 2015/6/14 7:28
I went with a different TB mounting setup.
#48 Re: States 1200 Coupe. (Oregon, US)
Mattndew76 Posted on: 2015/7/14 20:36
Next up on the CNC.
#49 Re: States 1200 Coupe. (Oregon, US)
ddgonzal Posted on: 2015/7/14 20:55
Nice, those Cowl Top Grilles are difficult to find.
Is it gonna be an alloy version? Never seen that done before.
#50 Re: States 1200 Coupe. (Oregon, US)
Mattndew76 Posted on: 2015/7/14 22:01
All Alloy.
Plenty of step down passes with the bull nose end-mill
« 1 2 3 4 (5) 6 7 »
