« 1 2 3 4 (5) 6 7 »
Re: States 1200 Coupe. (Oregon, US)
From Creswell, Oregon USA
That's a cool setup. Gives me the how to all in one place.
Good thing because I was about to Craig's List this one and save for the Winters swap instead.
Posted on: 2015/6/5 21:53
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
If you go to pick-ln-pull and get two ranger short-side axles you can shorten it to that.
Posted on: 2015/6/5 22:47
I'm unfamiliar with the term short side. Is that for straight axle front end?
Posted on: 2015/6/5 23:56
Parler @MDMachine
Ford Ranger 8.8 rear has an offset diff. One axle is long, one is shorter. See Rear Axle Swaps
Posted on: 2015/6/6 0:22
Using the short side shaft will put the axle at the right width for the 1200?
Posted on: 2015/6/6 20:44
Parler @MDMachine
Gotta have these welded.
Posted on: 2015/6/6 20:57
Edited by Mattndew76 on 2015/7/14 20:37:28
Parler @MDMachine
I went with a different TB mounting setup.
Posted on: 2015/6/14 7:28
Edited by Mattndew76 on 2015/7/14 20:36:47
Parler @MDMachine
Next up on the CNC.
Posted on: 2015/7/14 20:36
Parler @MDMachine
Nice, those Cowl Top Grilles are difficult to find.
Is it gonna be an alloy version? Never seen that done before.
Posted on: 2015/7/14 20:55
All Alloy.
Plenty of step down passes with the bull nose end-mill
Posted on: 2015/7/14 22:01
Parler @MDMachine
« 1 2 3 4 (5) 6 7 »
