Performance oil filter
From Sydney, Australia
can anyone recomend or know of a performance oil filter for the CA engines, i currently use the RYCO Z145A, no probs but would like to try something else.
Posted on: 2004/10/12 7:25
Re: Performance oil filter
How much extra performance is a performance filter good for?
Posted on: 2004/10/12 7:28
From sydney
Im trying a magna filter Contains a magnet inside to stop and metal from entering the motor.
Posted on: 2004/10/12 7:38
ok then, a filter that would be used on a race engine, so that it has higer flow rates (?) and most importantly has higher fitlering capabilities. As my oil is as black as midnight after 5,000 Km
Dont think a quality filter it will have any performance advantages, but will filter better and flow more therefore cleaner oil, and a better running engine, ideal for 'performance', dont you think DD???
Posted on: 2004/10/12 7:40
do you have a part number for this magna filter???
Will it need any mods???
Posted on: 2004/10/12 7:41
From Brisbane
What kind of oil are you running? It may have something to do with it going black quicker.
Posted on: 2004/10/12 7:46
mobil fully synthetic.
Posted on: 2004/10/12 7:57
From sydney
Will check the part number when i get home today.
Posted on: 2004/10/12 7:58
From Brisbane
Well there goes that theory
So I am assuming it is Mobil 1 then? I have used Mobil 1 in my other car and it stayed pretty clean for 10,000km's.
Sorry but I don't have any other suggestions
Posted on: 2004/10/12 8:23
From Brisbane, Narangba
I know its fuel injected but is it running rich. This could cause black oil. However rare on electonic fuel injected motors.
Also probably not the case as I assume the engine is new but the rings could be worn allowing blow by down into the crank case making the oil black.
Also remember if you flog it heaps you will have to change the oil more reguarly.
Posted on: 2004/10/12 8:30
