Fast Search Slow Search
Google Ad |
Browsing this Thread:
2 Anonymous Users
#1
Hilux Diff shortened to suit 1200
pro-12a
Posted on: 2005/3/17 23:49
Never used since built - work done by Craft Diffs, standard hilux brakes with new brake lines.
Can also supply complete with tramp rods, new wheelie bars and reset leaf springs. Diff only $1000ono or the lot for $1400 link to pics http://img183.exs.cx/img183/5324/img28rx.jpg http://img95.exs.cx/img95/5894/img00016hw.jpg
#2
Re: Hilux Diff shortened to suit 1200
benny
Posted on: 2005/3/18 1:51
Looks like a good price, for what appearrs to be quality built setup.
#4
bevo
Posted on: 2005/3/18 2:02
where you from? and will this bolt into a 1200 ute.. cause i have a mate that will prob buy it
#5
pro-12a
Posted on: 2005/3/18 5:02
I'm in Sydney, Blacktown area.
Diff will fit in ute for sure, but dont know if coupe or sedan's are the same dimension. These diffs are very tough and have been proven to handle 500hp
#6
bevo
Posted on: 2005/3/18 5:32
hi again is the diff just been shortened and the rest is standed.. LIke axels.. Anymore info would be good cuz i dont no much about this side of things.. thanks
#7
pro-12a
Posted on: 2005/3/18 6:28
The diff housing, axles and brackets are the only things have been modified
Axles are 30 spline. Has 4:3 Gear ratio and carrier is standard open wheeler but can lock it if need be.
#8
Dato1000
Posted on: 2005/3/18 11:05
hi, would this dif fit in to a 1000 ute? thank you
#9
pro-12a
Posted on: 2005/3/18 22:16
I'm not sure if it will fit in a 1000ute?
I will take a measurement from wheel hub to wheel hub when I get home.
#10
DVLDAT
Posted on: 2005/3/19 1:23
if the hilux is shortened for a 1200 ute it will fit 1000 ute as i had a 1200 ute diff under my old 1000 ute
