Hilux Diff shortened to suit 1200
Never used since built - work done by Craft Diffs, standard hilux brakes with new brake lines.
Can also supply complete with tramp rods, new wheelie bars and reset leaf springs.
Diff only $1000ono or the lot for $1400
link to pics http://img183.exs.cx/img183/5324/img28rx.jpg
http://img95.exs.cx/img95/5894/img00016hw.jpg
Posted on: 2005/3/17 23:49
Re: Hilux Diff shortened to suit 1200
From Sydney
Looks like a good price, for what appearrs to be quality built setup.
Posted on: 2005/3/18 1:51
From Warburton vic
Where abouts are you?
Posted on: 2005/3/18 1:59
From Campelltown,Sydney,NSW
where you from? and will this bolt into a 1200 ute.. cause i have a mate that will prob buy it
Posted on: 2005/3/18 2:02
I'm in Sydney, Blacktown area.
Diff will fit in ute for sure, but dont know if coupe or sedan's are the same dimension.
These diffs are very tough and have been proven to handle 500hp
Posted on: 2005/3/18 5:02
hi again is the diff just been shortened and the rest is standed.. LIke axels.. Anymore info would be good cuz i dont no much about this side of things.. thanks
Posted on: 2005/3/18 5:32
The diff housing, axles and brackets are the only things have been modified
Axles are 30 spline.
Has 4:3 Gear ratio and carrier is standard open wheeler but can lock it if need be.
Posted on: 2005/3/18 6:28
Quite a regular
From Whyalla
hi, would this dif fit in to a 1000 ute? thank you
Posted on: 2005/3/18 11:05
I'm not sure if it will fit in a 1000ute?
I will take a measurement from wheel hub to wheel hub when I get home.
Posted on: 2005/3/18 22:16
From sutho shire
if the hilux is shortened for a 1200 ute it will fit 1000 ute as i had a 1200 ute diff under my old 1000 ute
Posted on: 2005/3/19 1:23
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
