#1 Z18T + Gearbox
r30rally Posted on: 2005/5/28 1:45
Complete, but stripped down z18T & Gearbox. Details as follows:
Head has been rebuild and slightly ported, Still in brand new condition in the plastic after coming back from the machine shop Cost $700 just for the head rebuild. (See Pic Below)
2mm oversize pistons, Copper Head gasket. The block and pistons have been measured and are well within their acceptable limits to putback together. Will need only new bearing I guess and a gasket kit.
Modified Intake Manifold by plazaman to accept 65mm throttle body, Custom fuel rail and FJ20T injectors and XF 65mm throttle body.
Standard Turbo with minimal shaft play and as mentioned above z18T 5 speed.
As far as I know everthing is here, sump, dizzy, head bolts, flywheel, clutch (Needs new one though) etc etc.
I'm after $800 for the lot, thoughI would defintely consider a swap/trade for an 280zx L28 motor with cash adjustment either way depending on condition. Any questions don't hestitate to ask.
#2 Re: Z18T + Gearbox
ISL33P Posted on: 2005/5/28 8:10
sorry to ask, but will you sell just the throttle body ? if not, no worries.
#3 Re: Z18T + Gearbox
kegs Posted on: 2005/5/28 8:34
hey 1sl33p why not try ur local wreckers, im sure a t/b off a xf or any 4 litre 6 will be about the same, and easy to get i imagine ????
#4 Re: Z18T + Gearbox
r30rally Posted on: 2005/5/28 9:12
Dude,
Your better off just going to the wreckers and they'll charge you about 40 or 50 bucks. Closer to home as well
#5 Re: Z18T + Gearbox
TnPshow Posted on: 2005/5/28 13:18
Where are you situated???
#6 Re: Z18T + Gearbox
ISL33P Posted on: 2005/5/28 23:38
that's why i asked, i have sucked them dry and now they are asking $100+, what a rip off.
thanks anyway for considering.
#7 Re: Z18T + Gearbox
r30rally Posted on: 2005/5/29 6:50
Sorry I'm in Sydney fellas
#8 Re: Z18T + Gearbox
r30rally Posted on: 2005/6/17 12:02
I'm open to offers on this package as I'm pretty keen to get rid of it out of the shed
#9 Re: Z18T + Gearbox
SILVERBAK Posted on: 2005/6/18 3:09
pm sent
#10 Re: Z18T + Gearbox
NP037 Posted on: 2005/6/18 11:43
does it come with computer and harness???
