« 1 (2) 3 4 5 »
Re: wheels
Quite a regular
From south brisbane
i have standed struts on a 1200 ute and was after a set of crome 15 inch with low pros has anyone seen it done and is it hard to to find the rims
Posted on: 2005/11/16 9:37
Re: wheels
From Newscastle, Australia
I have seen R33 Skylines with 4 stud 114.3 PCD so that opens up a huge range of wheels available to you. I have long wheel studs and spacers on my race car...with almost a FWD offset and they look and perform great.
Posted on: 2005/11/16 9:49
Dont die wondering.....
Re: wheels
From Adelaide, Australia
Dont pimp your ride! You'll have to go to stanza struts and run fwd wheels im sure. Better off with some nice wide 13/14's i reckon. Otherwise it'll look pox. Just my view.
Posted on: 2005/11/16 9:55
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: wheels
From Stray-ya
If you want 15's you can go for sirocco's (ROH i think) You can get them as blanks and have whatever offset & stud pattern you like, but it will take a bit of budget. They dont look too "pimp" as long as you dont go for the chrome ones
Otherwise minilites & globes come in a few RWD offsets that should fit (i.e. +21) A 15x6 +21 will give you about 110mm backspace so that would be marginal for a 195/50R15 when you take into account tyre bulge...... But I'm not sure if you can get a 195/50/15 onto a stock strut anyone done it?
Unfortunatley most of the commonly available 15 rims are 6.5" wide which means you have to have a really low offset- and would risk breaking stub axles...... but it's academic because they generally only come in FWD offsets anyway
Posted on: 2005/11/16 10:54
Re: wheels
What about some of those jap import SSR mesh 3pc rims, theyd look a treat.
Posted on: 2005/11/16 11:04
IPRA Build
Re: wheels
From sydney
The best period wheel for your Datsun will always be the 8 spoke RS Watanabe, super light and look just right.
13x7s with a 112mm backspace will be perfect for a 205 tyre.
Posted on: 2005/11/16 13:10
Re: wheels
From Brisbane, Australia
Duncan, i'm running 1400 sunny discs which increase the offset & I will probably have to slightly turn up the front guards. I think the original struts are fitted but i'm not sure as I didn't do the work. I still think these are the best wheels as I test fitted them on the rear with 205,s & the clearance inside & out matched perfectly.
Posted on: 2005/11/16 13:38
Re: wheels
Posted on: 2005/11/16 13:39
Re: wheels
From Huntington Beach, California
Thanks for the info. My car currently has 185/70-13's on what I believe is a Sunny rim. I would like to go panasport/minilites as I like the way they look on the Datsuns. I don't think I really need a much wider tire, but a 185/60 in 14" might be pretty cool.
I may put an A14 / 63A combo into my Datsun, but it's for street driving only. So I think a 185/195 width would look nice and perform well for street use.
Posted on: 2005/11/16 22:25
Re: wheels
From mildura, victoria
these are the wheels im after does anyone now wat they are called?Open in new window
Posted on: 2005/11/17 11:50
« 1 (2) 3 4 5 »
