more questions: A12 to A14 switch
From Las Vegas USA
Now that I am going to run a couple of Tarmac Rallys I need a motor that will pass smog easily so I'm thinking use near standard A14 or maybe A15.
Swapping from A12 to A14 other than motor mounts what is differant? Will my 1200 tranny bolt right up. Also will the 550KG pressure plate from A12 work? I have a slightly hotter Cam for A12 will that fit in A14. Finally anyone know the HP ratings for stock A14 or 15
Tom Grossmann
Posted on: 2003/7/18 21:55
Re: more questions: A12 to A14 switch
Block is about 3/4 inch taller. Exhaust may or may not bolt up depending on how much play is in the bend of the pipe.
Yes.
No, the 1973 and older motors use a different cam from 1974 and newer. The distributor changed places.
Posted on: 2003/7/19 1:43
anyone know the HP ratings for stock A14 or 15??
From campbelltown (sydney) australia
1200 rally cars site says that both the a12-15 have 69hp while the a14 has 80 hope this helps
Posted on: 2003/7/19 11:36
