a12 problems
From Bris-vegas
g'day guys
i'm having a little problem with the ol' a 12, in the morning when i start it up it will cut out imediately after taking my foot off the accelerator. it's not cold enough yet for the choke and yes i've tried that. it's ok once it's warmed up a bit but yeh, is there something i can adjust or change to fix this annoying problem.
cheers
Posted on: 2006/4/3 2:18
Re: a12 problems
From Merimbula,NSW, Australia
theres a good artical on that in this forum,really helpful type in 'engine keeps cutting out' in the search bar. hope it helps
Posted on: 2006/4/3 2:28
Re: a12 problems
From Bris-vegas
thanks mate
Posted on: 2006/4/3 2:30
Re: a12 problems
From Bris-vegas
alright that was helpfull, befor i go stick my head in the ute again, how do you adjust the throttle cable?
Posted on: 2006/4/3 2:36
Re: a12 problems
sorry cant help u there, i had to take mine to a mechanic, i had the same problem.
Posted on: 2006/4/3 2:54
Re: a12 problems
From Brisbane
I have the same problem with my ute
I replaced the stock carby with rebuilt and tuned Weber DGV but still having the same issue.
Starts easy just needs to hold the accelerator pedal for few minutes otherwise it will stall.
Played with the choke and idle setting still no luck.
done normal service spark plugs, points etc
Posted on: 2006/4/3 13:19
Re: a12 problems
Not too shy to talk
From Guatemala, Central America.
I experienced the same problem when i changed my carb's jets, i was using a #95 main jet and evetything was fine, now i'm using a #92 and this problem appeared.
Posted on: 2006/4/3 22:52
Re: a12 problems
Not too shy to talk
This is normal in some way because when the engine is cold the mixture can't be burned complitly, that's why computer controled engines provide a richer mixture and a little higher rev speed while the engine is cold, some newer carbs does this too, but anyway i think that you should check the ignition timing, and idle mixture, and check for vacuum leaks that could be causing a lean mixture problem too.
Posted on: 2006/4/3 23:02
Re: a12 problems
dont know if it will help but try looking for gaps in your head gasket maybe even carby i was missing the gasket in both and sealed them with a new gasket and gasket seal and it gos heaps better
Posted on: 2006/4/4 2:33
Re: a12 problems
From Bris-vegas
funny you should say that because the seal in the bottom of the carby is broken. i'm going over to my mates place on saturday and we'll have a tinker with the timing and the carb etc. hopefully we can get it a little better.
it was suggested that a weber 32/36 down draft with a set of extractors could help, but was mentioned in a previous post here.
cheers guys
Posted on: 2006/4/4 3:09
