Re: Tacho Connections
firstly glad we are getting somewhere!
But sadly you worry me when you talk of the black / white loop!
The way you describe it is that it is one wire running in a loop and joining back to itself while it swings in the breese.
If this is the case you have it wrong!
You need this loop black/white wire and you need to look dirrectly behind the tacho gauge at the wiring harness, here you should find taped in a bit of coloured tape another black/white wire, it will have connections in it , and to this you join the looped black/white wire.
Now the other wires.
I dont know what the box is as i cant see it.
Simple and easy way to tell you how to do it is :
The black wire connect to ground.( earth, body etc)
The red / yellow connect to 12V ignition supply( 12volts when the ignitiion is on and 0volts when it is off)
Posted on: 2002/12/23 15:55
Subject Poster Date
     Tacho Connections Buff 2002/12/18 4:15
       Re: Tacho Connections dattodude 2002/12/18 4:52
         Re: Tacho Connections ddgonzal 2002/12/18 5:25
           Re: Tacho Connections dattodude 2002/12/18 5:40
           Re: Tacho Connections phunkdoktaspok 2002/12/18 6:46
       Re: Tacho Connections phunkdoktaspok 2002/12/18 7:02
         Re: Tacho Connections Datopower 2002/12/18 19:03
           Re: Tacho Connections ddgonzal 2002/12/19 7:23
           Re: Tacho Connections phunkdoktaspok 2002/12/19 12:48
             Re: Tacho Connections Datopower 2002/12/19 18:55
               Re: Tacho Connections Buff 2002/12/20 1:51
                 Re: Tacho Connections phunkdoktaspok 2002/12/20 13:06
                   Re: Tacho Connections Buff 2002/12/23 3:59
                     Re: Tacho Connections brendon 2002/12/23 7:00
                     Re: Tacho Connections phunkdoktaspok 2002/12/23 15:55
