Help!!!
Not too shy to talk
From South Africa
Hi Guy's.
I need a little help or advice from you if possible.I have a mazda B1300 ute.I am busy fitting a highly modified A15 motor and gearbox in it.Unfortunately I don't have an Datto UTE body though,but anyway,I have the original diff. with 3.81 ratio.I'm currently waiting for my aluminium propshaft to come back.Do you think this diff will do the trick or do you think I should fit the A1400 ute diff.I.m planning to run a huge turbo and some nitrous.
Posted on: 2003/1/25 16:50
ROLAND
Re: Help!!!
From sydney australia
the only way to be sure is to run it & see.seriously,it's already in the car,you've got a tailshaft coming,& it might hold up perfectly well with just the a14.i'm not sure of mazda philosophy for commercials,but japanese commercials seem to come with tough rear ends.so give it a go,is my opinion (humble or otherwise).then,if it comes apart,try for the diff from a 520 ute,these are bigger than 1200 ute,& an alloy centre.
Posted on: 2003/1/25 23:09
Re: Help!!!
From Melbourne, Australia
is the 520 diff a h-190 or what?
is it wider than a h-165?
same width as h-190?
Posted on: 2003/1/25 23:15
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Help!!!
the 520 diff is a h190 centre,but is the same track (or very close) as a 1200,so it will go into a 1200,but you have to redrill the axles from 6 stud to 4 stud.i'm not sure of the ratios,but it is a big axle one,so anything from a series 3 b/bird,or gazelle,or 720 ute,should fit.
Posted on: 2003/1/25 23:30
Re: Help!!!
is the alloy centre a lot lighter?
what ratio is the alloy centre, that is my main attraction but if i had to swap in a b/bird centre i loose that benefit
Posted on: 2003/1/25 23:33
1200 Coupe Rallycar
Re: Help!!!
quite a lot lighter in fact,a case of one hand versus two.
Posted on: 2003/1/26 5:31
Re: Help!!!
does anyone know the ratio of the alloy centre, its kinda important
Posted on: 2003/1/26 7:30
1200 Coupe Rallycar
Re: Help!!!
From Warwick, QLD
How long is the H190 diff?? Does it have greater track then teh H165 ute diff??
Cheers
Damo
Posted on: 2003/1/26 11:33
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: Help!!!
the h190's im familiar with out of vanettes and stuff have 90mm wider track, not sure bout this one though sounds like its inbetween vanette and 1200 size
Posted on: 2003/1/26 12:04
1200 Coupe Rallycar
Re: Help!!!
sorry michael,took a bit of time to get the info you want.the diff is a 4:11.1 ratio.it is an alloy centre.it's the same track drum to drum as a 1200.it's also the same length as a h165 diff centre.i got this info from a friend,who also told me they change the bearings from roller to normal.he also has one in his shed,but doesn't know how much it's worth.this is in sydney,the suburb is silverdale.i suppose we could always see if it'll fit in a post pack or something.
Posted on: 2003/1/29 8:12
