engine swap
From Ballarat, Victoria, Australia
is there any probs dropping a standard A12...
out of a ute...into a 4 door sedan...
Posted on: 2003/3/9 3:13
-1200 4 Door Sedan, 2Pac Aruba Blue, Custom White Interior, OBX Racing Seats, SONY Head Unit, FUSION Speakers, 14" Bathurst Globes, Lowered, Powered By: A15 with Twin 40s,
Re: engine swap
No problem swapping a 71-73 ute engine into a sedan or coupe.
Apparently the 1971-1973 A12 differs from the 1974-up A12. The engine mounts presumably are different. If so, you just need to make the usual A14 mount modifications. See the Tech Section article How to fit Datsun A14 & A15 Engines.
Posted on: 2003/3/9 6:19
Re: engine swap
thanks 4 that...still learning...i'm having to put in an engine in my recently purchased 1200 sedan, that i got out of a ute 4 100 dollars...goes fine too...b'cos me old ones blowin steam out the exhaust...and leakin water every possible place...and now she went and ceased up on me...
Posted on: 2003/3/9 6:58
Re: engine swap
Not too shy to talk
From brissy & sometimes melbourne
Hi just reading. I don't know if this any probs or if you are looking for one, But if you need one I have drop mine out and put in a ca18. The a12 is running.'' Where'' Don't know but it go's.
Posted on: 2003/3/10 13:15
Re: engine swap
yer do actually smurf...tried 2 drop tha new engine in today...but she was out of a later model ute...so we had some problems...but i am in desperate need of one...if you could reply with some more details etc. would be much appreciated
Posted on: 2003/3/10 13:33
Re: engine swap
Not too shy to talk
the engine mountings on a ute are 1.5" further back, ute crossmember ears go straight up ,old coupes sedans wagons X member ears lean 4d
Posted on: 2003/3/12 13:02
Re: engine swap
Not too shy to talk
verry eazy to get around with small flat plates to move eng mounts 4d
Posted on: 2003/3/12 13:04
Re: engine swap
From Melbourne, Australia
Posted on: 2003/3/13 8:12
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: engine swap
Not too shy to talk
Hey sorry for the delay having probs with this ####ty computer. I don't know if you got the email I sent you the other day. I'll give you a name & number where you can see it?
Datsun 1600 workshop ph 039714743 speak to randy, He'll be help you!Quote:
Posted on: 2003/3/13 9:36
Re: engine swap
is that your ute randy was putting the ca18de into down there???
Posted on: 2003/3/13 9:38
1200 Coupe Rallycar
(1) 2 3 »
