Ford 9" Diff Conversion
From Portland, Vic
Ok, so now that I have decided on an engine and gearbox combination for my 85 datto ute (Series 5 13b turbo), I thought I might actually swap the diff out for a Ford 9" job while I get all the other parts together. Now, what I need to know is, if I am looking around for this diff, what should I be looking for, ie. should it be out of a specific car, does it need to be a 9" that has certain parts, etc on it? I am doing it this way, as it works out a bit cheaper than having a custom one made ready to bolt in. I got a quote for this today and it was $1850 complete and ready to bolt into the ute, add to this another $200 for skyline rear brakes with a handbrake setup.
So yeah, if anyone knows which one I should look for in particular to suit the suspension setup/layout of a datto 1200 ute, information would be appreciated.
Thanks.
Leigh
Posted on: 2003/3/11 4:02
Re: Ford 9" Diff Conversion
From Kyabram vic, aust,
I dont think you woll get any 9 inch diff to fit with out modification, their all too wide
Posted on: 2003/3/11 4:11
From Portland, Vic
I am aware of that, considering how much narrower a 1200 is than any ford that uses a 9" diff from factory!
Posted on: 2003/3/11 4:15
From Brisbane, Australia
I think what go_the _datto is getting at is the housing and axle shortening is the part that will cost you the money...the $1850 'custom one' is not made from scratch, it's just a shortened 9". Only difference will be that you will be suppling them the axles and housings.
Posted on: 2003/3/11 4:31
From Adelaide
yeah ford 9inch is a big diff heavy and takes a lot of power to turn you migght kick my idea in the guts and thats cool but this is what i did i brought a VP commy diff for 400 bucks and spent 600 getting it shortend stud pattarn changed suspension mounts modified and then use the commodore brakes i got with the dif pretty cheapf
Posted on: 2003/3/11 10:04
From Portland, Vic
No, you are pretty well right there. Did quite a bit of ringing around yesterday, and have decided to go for a VN onwards LSD. I thought I might just change my stock diff's centre for an LSD one, but I am looking at $2500 for a new one, or $1200-$1700 for a second hand one....Commy diff is now on the cards, and hopefully it will be nice and strong. Has anyone had any bad experiences with them?
Leigh
Posted on: 2003/3/11 22:12
You should put in the lightest diff that is strong enough (with a margin of extra strength). There's no advantage in making the car heavier than normal.
For example, the Ford 8.8 has 95% of the strength of a Ford 9 inch, but weighs something like 30% less.
For a road or road-racing car, having less weight under the springs will help improve handling and give a smoother ride.
OK, there's one advantage to the heavy diff -- if you can get one inexpensively compared to a lighter but more expensive one.
Posted on: 2003/3/12 6:28
Not too shy to talk
if u fit a 4d 9" it would b a disadvantage to big nothing wrong with a borg warner 78 or as some know as 8 & 3/4 they go alright behind4d xa's thrugt to au falcons or holden vl to vr old fords 25 spline new 28 sp all holden 28. best diff for 1200 con is a 28sp skyline use the disk brakes and all i use to work 4 diff trans spares in sydney dun heaps of cons.
Posted on: 2003/3/12 11:46
The Ford 9" can handle about 500 lb-ft of torque. 1200s like Rigoli's 9-second ute, or Waylands electric-powered 2-dr sedan require this kind of strength.
For Ford 9" prices and a little more info, see the Tech Section article What Diff and LSD should I use?.
Posted on: 2003/3/14 16:13
Not too shy to talk
From Brisbane
In the tech section, it says this:
Some reported non-narrowed rears are (with possibly the assembly a little wider) are:
- Falcon ute complete rear which gave you LSD, a live rear, and discs
Does anyone have any idea which Falcon ute it is? And I would assume this is not the 9" diff? It'll have to be a fairly small ute to have a diff that will go straight into a 1200 without shortening, how long is it?
Thanks
Posted on: 2003/5/28 15:35
