10 psi
From south australia
do you think a stock a15 can handle 10psi boost without a head gasket shim? keeping in mind i have full programable wolf 3d injection
Posted on: 2007/6/24 2:19
Re: 10 psi
Not too shy to talk
From perth wa
i am onto my second a14 running 12 psi. the first one lasted about one and a half years of punnishment which isnt to bad.
but for the next engine i will be downsizing down to 8 or 7 psi
Posted on: 2007/6/24 2:27
why is it that the wife does not think i am serious when i say she will go before the datto ??????????????
Re: 10 psi
i might be right then i dont drive it that hard.
i replaced the head gasket shim with a slightly thicker one and the power droped by heaps
Posted on: 2007/6/24 2:33
Re: 10 psi
Not too shy to talk
From perth wa
it sounds like it should be alright then. i am going to build the expired engine i have to the tilt so we will eventually see how much boost an A series can handle.
Posted on: 2007/6/24 2:53
Re: 10 psi
Not too shy to talk
From perth wa
is ur engine injected or blow through??????
Posted on: 2007/6/24 2:54
Re: 10 psi
its supercharged blow through fuel injection
Posted on: 2007/6/24 3:00
Re: 10 psi
Not too shy to talk
From perth wa
have u had yours on the dyno.
i have not yet had mine but am expecting around 120hp mark.
12psi was a demon to drive in the wet..
Posted on: 2007/6/24 3:07
Re: 10 psi
that souunds about right
before i changed head gasket shims i was getting 112 rwkw but now it has droped to around 65 rwkw but stll pulling 270nms of torque
Posted on: 2007/6/24 3:10
Re: 10 psi
From Melbourne, Australia
if the tune is good it should last a longtime
why would you drop compression to only run 10psi...
pointless in my opinion
Posted on: 2007/6/24 3:49
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: 10 psi
it was the way i baught it
Posted on: 2007/6/24 4:16
