what vannette parts can be salvaged?
From Brisvegas, oz
i recently accuired a 83 nissan vannette, thinking it was going to have the a15 engine but it only had an a12, so now im stuck with a van and lots of parts, what parts can be slavaged and used on other dattos
Posted on: 2007/7/1 9:34
www.camerasplus.com.au
Re: what vannette parts can be salvaged?
From Townsville, Qld
besides the obvious spare engine you ahve now you can grab the gearbox, rear axle assembly, brake master, front hubs disks and brakes (got a suspision here hey may have some bolt in qualities with other struts), front seat since it's nice and simple for any projects.
I can't think of anything more atm but I'm sure there was more I could have grabbed off mine when I had it
edit: probly the door handles too but I'm unsure if there were any differences in them compare to other cars.
Posted on: 2007/7/1 9:39
From In front, and pulling away.Sometimes around Sydney....ish!
Radiator is normally three row if it is fitted with air. Easy upgrade.
Posted on: 2007/7/1 9:42
Lifes good when your on BOOST!
From sydney
They have a transverse front leaf like a 1000 and I have heard of suspension bits and brakes being modified and swapped over.
Posted on: 2007/7/1 9:50
From Brisvegas, oz
yeah i noticed the front suspension was like the 1000s and its got discs, and as for the booster its way to big for the 1200 damn.
Posted on: 2007/7/1 9:57
notice that it's a reversed one though?
Posted on: 2007/7/1 10:27
From Brisvegas, oz
no i didnt actually
Posted on: 2007/7/1 10:33
From Melbourne, Australia
diff should be h165 with ratio of 4.9:1 (housing too wide by 90mm but centre is good)
awesome acceleration, top speed around 160 with an overdrive 5 speed
master cylinder is like 15/16ths (big mother) as well for big brake upgrades
gearbox is only good for some parts
Posted on: 2007/7/1 11:03
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Brisvegas, oz
would it take much to switch the diff centre cos the one on my ute is a little worn
Posted on: 2007/7/1 11:06
From sydney
Pull your axles out a couple of inches and the diff centre will be easy to swap, but with your turbo motor you wont need a ratio that low as you will have torque to burn anyway.
Posted on: 2007/7/1 11:38
