Trx brakes
From brisbane, qld
Ive got a pair of trx axels with brake backing plates and handbrake set up on them, without disks but i have a set of calipers to go with them.
The only thing is that one backing plate is cracked and will need to be welded up to be used.
Most of what you need to convert a ute rear axel to disk is there. Just have to buy new disks.
Im after say 80 bucks for the lot.
PM me if interested
Posted on: 2007/7/4 9:22
Re: Trx brakes
From Adelaide, Australia
I have 5 sets of backing plates if anyone needs one to complete the setup.
Posted on: 2007/7/4 9:29
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: Trx brakes
Quite a regular
From Brisbane
will this setup suit a coupe?
Posted on: 2007/7/4 10:29
Re: Trx brakes
These brakes will fit any of the H165 rear ends. Where you stick your rear end is up to you, but the H165 that comes from under a 1200 ute is easily installed under a 1200 Coupe.
Not a direct bolt-in, but quite close.
Posted on: 2007/7/4 10:38
Love your Datsun.
Treat it well.
Re: Trx brakes
hey mate im in syd n have a 1200 ute that i could use the brakes for. are u willing to post them down?
Posted on: 2007/7/4 10:46
Re: Trx brakes
From brisbane, qld
Im not sure if aust post will take them as they are, since they are attached to axels.
But they could probably be couriered. Not sure how much though.
Posted on: 2007/7/4 11:28
Re: Trx brakes
From Melbourne, Australia
people wont use the axles for the conversion.... so why not cut the bush the holds the wheel bearing off with an angle grinder and just send the backing plates?
Posted on: 2007/7/4 11:31
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Trx brakes
From Geelong, Vic
or just cut the axle off after the bearings....nothing an angle grinder cant handle
these will also fit late h145s(120y ones) h150s and h190s
Posted on: 2007/7/5 3:37
Re: Trx brakes
From Toowoomba, QLD
ill take em off you just dont know when ill be in brisvegas next. Im in toowoomba
Posted on: 2007/7/6 4:23
Re: Trx brakes
From brisbane, qld
Show me the money and they are yours whenever you want to pic them up.(within a reasonable amount of time)
Posted on: 2007/7/6 4:54
