diffs diffs diffs
From Auckland N.Z
I need to know the fool proof way to tell the diference between the 145, 150 and 165 diffs. I want to put a ute (165?) diff in my coupe and i know utes also came out with the same diff as the coupe (145?) and i want to muke sure i buy the right one. is there any way to tell by looking at them?
Posted on: 2003/4/5 16:03
Re: diffs diffs diffs
I've been thinking about this. They aren't marked with a tag (like Ford diffs), and they are all have eight-bolt "pumpkin" (head). So the first ID point is to look for a removable center section.
The H145 and H150 look identical on the outside. The H165 is bigger. I think you'd have to measure the dimension of the outside to tell.
Does anyone know if there are unique casting marks?
By the way the H165 and H165b are pretty much the same (center sections interchange), but the "b" models have stronger gears.
Posted on: 2003/4/5 23:00
From Auckland, New Zealand
Quinn,
I have a H145, a H165 ex a ute & a H165 ex a C20 van sitting on my garage floor.
I'll have a good close look at them all and see if there are some specific castings marks, but from memory the only castings marks are on the diff head (or centre) which of course is very easily interchanged anyway.
When you see and H165 & H145 side by side the differences are very obvious.
Your biggest problem is going to be finding the a ute diff and to my knowledge all "roadstar" utes have the H165, if you find one with an H145 its because someone has already robbed the H165 & relaced it with a H145.
Posted on: 2003/4/6 0:18
From Melbourne, Australia
to help soeone before i measured from the top point of the centre of the diff, to the bottom point, there was about 20-30mm diffrence, maybe you could search for the results but itll prob be hard to find
Posted on: 2003/4/6 1:02
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Auckland N.Z
cheers guys im going to have a lok at a ute thats being parted and ill tell you if i find anything. Hey Brent you wouldnt want to part with that h165 diff?
Quinn
Posted on: 2003/4/6 1:46
Quinn,
Which H165 would you want?
I have in stock ........
2 x complete H165's ex utes.
1 x housing H165 ex ute - no axles or centre.
1 x complete H165 ex C20 van - wider than the ute (not sure by how much but think its around 50mm)
Brent
Posted on: 2003/4/6 2:10
From canberra australia
ute diffs have the brake hose conection on the opesit side of the diff to coup and sedan well thats what i found cause i had to put a coup diff in my ute
Posted on: 2003/4/6 3:26
i dont drink beer i drink BEERS
From Auckland N.Z
hey Brent i would love one of your complete h165 ute diffs, how much do you want for one of them?
Posted on: 2003/4/6 15:06
Hi Quinn,
The problem is that I want all my ute diffs, as I'm currently building a second coupe, but you could also say anything is for sale at the right price, a ute diff is probably worth more to me than what you'd be prepared to pay.
Brent
Posted on: 2003/4/7 0:19
The h165 is phisically bigger and the axles ends are thicker too best use a tape measure from diff housung top 2 bottom and axle housing diameter.
Posted on: 2003/4/7 1:04
