Re: Converting 4 door 1200 sedan to 2 door (photochop pics)
From sydney
Anything is possible as long as you put your mind to it hope to hear how you go
Posted on: 2007/9/20 7:32
From Perth W.A
The 1200 post is shorter than a 1200 sedan this you must consider when building your toy
why do you call it a 1200 post?
PS build it!
Posted on: 2007/9/20 8:09
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From Wellington New Zealand
The trick is to use the longer wagon/van doors as these match the windscreen pillar angle and are the same height in the door opening. Then slice the B pillar and shift it back to suit.
Posted on: 2007/9/20 8:24
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
dazzasute wrote:
You'd have to get custom... I s'pose its not that bad since glass in 1200's is straight!
Don't let me put you off though, go for it
1200 glass is not flat. And you will be paying good money for an Australian Automotive ADR approved glasier to make the glass. ( I researched long and hard when i chopped my old 1200 wags.)
4 door sedan rear door glass swapped to opposite sides will give extra length but may or may not wind all the way up because of the curve needed at the top front. Moving the Bpillar on 1200's is as easy as drilling out the spot welds and sliding it into the desired position.
Posted on: 2007/9/20 8:36
From sydney
just all ways known them to be 1200 post mine came from south africa in 69 ive owned it for 16 years now
Posted on: 2007/9/20 9:34
Is yours a B110 1200, or or the older style Bluebird 1200??? Production of 1200s (B110 series) started in Jan 1970... here's the photo of the first 1200 off the assembly line:
Jan 1970
Posted on: 2007/9/20 21:11
From sydney
b110 1200 one of the first
Posted on: 2007/9/21 2:22
« 1 (2)
