Fuel line fittings
From SE Melbourne
I'm about to start bending my own fuel lines, and wonder what you do for the ends - which then need to connect to rubber hosing.
Is the idea to flare the end of the pipe, and put a threaded fitting on the end of the pipe (like a brake line) - and then screw another fitting onto that.
So one of these
and something like this
Is a single flare sufficient, or do you need to double flare for EFI?
Posted on: 2007/10/3 3:20
Mildman, Datsunless
Re: Fuel line fittings
From Melbourne, Australia
i would get a flare kit (cheap ones dont work though) and flare it like the right hand end in the top picture
even better would be to get a place like pirtek to flare it for you
Posted on: 2007/10/3 4:44
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
if you have a decent speed shop close by the guys will usually flare the ends at no charge (or minimal cost) and that will keep you out of truble
Posted on: 2007/10/3 5:05
Don't You Just Love Owning a Road Registered GOKART
From Sydney, Australia
if you are running 35-45psi, using good quality stainless steel EFI hose clamps should be sufficient. You need the ones that protect the hose, not the generic ryco ones you get at local auto store.
I recommend going to the wreckers, and getting a dozen of them from an R31 skyline. or similar.
Take a sample of your EFI hose, as there are at least 2 different outer diameters of 5/16th EFI rated fuel hose.
Posted on: 2007/10/3 5:08
From SE Melbourne
Do you still need to flare it if using EFI hose clamps. (I've got a few EFI hose clamps - picked them up from EFI hardware last time I was down there).
I've got a 'double flaring' tool - but it cannot create the flare that 1200rc recommends...more like a trumpet at the end of the pipe.
Posted on: 2007/10/3 6:08
Mildman, Datsunless
From Perth W.A
you need a tool used by plumbers or anyone who works with soft metal pipes, they have a tool which will "baloon" the ends, like on the factory hoses.
can't remember the name of the tool at the moment...
Posted on: 2007/10/3 6:18
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From SE Melbourne
There's an exhaust place and a couple of mechanics at the end of the street - I might go see if they are able to make flares on pipes. Might be cheaper than buying a super tool to do it.
If not I could just try my double flaring tool, it's a super cheap ebay job though...
Posted on: 2007/10/3 12:59
Mildman, Datsunless
From Adelaide, Australia
Your flaring tool is for brake lines Mildman.
Posted on: 2007/10/3 13:06
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From SE Melbourne
Yeah that sounds about right Mr.Sedan.
Is there also a flaring tool for fuel lines?
Posted on: 2007/10/3 13:07
Mildman, Datsunless
Ive just been looking, nothing on ebay, im interested as well.
I need to get a brakeline flaring tool, im sick of my spaghetti brakelines after the last brake upgrade and would like to do them myself, if theres something that does it all would be good.
Posted on: 2007/10/3 13:14
IPRA Build
(1) 2 3 »
