Re: 12" wheels on 180 struts towers?
From Geelong, Vic
stanza
Posted on: 2007/11/4 6:48
From Wallan, Vic, Aus
ah okay Pigdog, so its a stanza caliper your saying? I found out that it is a 200B rotor. But what about the front ends, is there a difference between 180 and 200?
Posted on: 2007/11/4 11:32
From Geelong, Vic
nah it will be a stanza rotor as well i would think
difference between 200b and 180b struts or the whole front end?
main difference in struts is the different caliper spacing
Posted on: 2007/11/4 23:05
yeah, I meant the whole front end? Remember when i came up to your place and my car had that huge negitive camber, because I have a 240K front end? Well I want to change it to try and get rid of that negitive camber, as when i drive down the highway, the car keeps pulling side to side the whole way. So if that is a stanza rotor as well, then what front end would you suggest, the car has an L20B in it. The prvious owner says it had 200b brakes. He must be wrong
Posted on: 2007/11/5 1:06
Okay I've done it, as follows:
200b Struts
200b Rotors
Late Stanza Girlock Calipers
About 6 - 8 mm Spacer Plate
And a grotty little 12" rim.
My struts are 240k ones, but ive been told they are the same as 200b. But the backing plate behind where the rotor goes is differnt, the 240k one goes around more. So i just removed it. 200b one will be fine.
Posted on: 2007/11/13 8:51
From Geelong, Vic
200b rotor and stanza calipers? pretty sure they are stanza rotors
drove on 12s today for the first time since i got the car and damn was it the most unsafe ive ever felt in my car
they do spin really easy though which is about the only good thing about them
Posted on: 2007/11/14 12:20
« 1 2 3 4 (5)
