BOV/cooler piping questions
From Canberra
Just a couple of questions, I'm almost up to the stage of repiping my intercooler and need some opinions.
Can I weld my blow off valve onto the intercooler end tank? I figure functionally its exactly the same as being on a pipe, but I've never seen it done before.
What is the best way to prepare a alloy pipe for a silicon hose? A bead of weld, flaring the end, or a flare a cm from the end?
Any opinions welcomed :)
Thanks
Posted on: 2007/12/26 8:08
Re: BOV/cooler piping questions
bov works best closest to tb
i wouldnt touch it
Posted on: 2007/12/26 8:12
From Sydney
Welding to the end tank can be done depends on how the intercooler was built from wat ive been told some intercoolers(usualy stockies) include some sort of glue and yea when u weld it the glue melts or somthing, just wat ive heard..
Posted on: 2007/12/26 8:15
From Canberra
Its a custom cooler with a nice large flat area on the end tanks, would be heaps easier to cut a hole in that and have my rb25det adapter welded to that than to have it welded to a 2" pipe (i'm thinking cheaply here ) I realise they work best close to TB, but I've seen them on the turbo side a lot so I'm sure 20cm wont make a huge difference.
If I "dont touch" the piping will it not just blow off under boost????
Posted on: 2007/12/26 8:21
From Melbourne,Australia
Ive seen bov off valves mounted directly to an end tank and dont see why it would affect the way it functions as this is what wrx's and gtir pulsars have from standard. As far as piping go's definalty have a few beads of weld or have a exhaust shop roll a lip on your piping a was forever blowing of hose's until a had it done
Posted on: 2007/12/26 8:30
From campbelltown (sydney) australia
unless ur runing huge boost the pipes will be fine i have nothing on mine and have run 18 psi before with just normal hose clamps, as long as theres a fair 20-30mm inside the hose it will be cool. as for the i/c mounted bov if ypoure going to do it make sure u stop swarf getting into the core coz its going to be hard to see whether its all out id steer clear myself, and just not have a bov never had any problems without one and makes a tough sound too.
Posted on: 2007/12/26 8:34
* caution, sunglasses must be worn to view my ca18det *
i havent blew 1 yet and i have a twin turbo v8 and a turbo 4banger(datsun)
and the coolers this guy is talking about are mounted on top of engine close to tb
ive seen them in the wrong possition before such as on other side of cooler
depends if you want for looks or performance
Posted on: 2007/12/26 8:38
Just offering my opion guys
Posted on: 2007/12/26 8:42
From Canberra
cheers for the replies, swarf shouldnt be a problem if I'm careful about it.
I'm not going to run it with no bead, I was just wondering which is the best way. I was planning to just put a little flare on the end with a cone/ball shaped object slightly larger than 2", but was worried about the alloy pipe cracking rather than flaring...
Posted on: 2007/12/26 8:53
what are you doing
are you turbo the gze
or
taking the supercharger off and going single turbo
Posted on: 2007/12/26 9:43
