Re: The oil smoke blues
From Burbank, CA
So initally it was hooked to manifold vacuum, then that's where it should stay or it will see odd things like unusual vacuum spikes, moving it back and fitting a check valve should fix that. the ones used on the vacuum advances here were something called a vacuum delay check valve, so that cause issues, I think the delay was in releasing vacuum, but not sure, so those might or might not be a problem...
Posted on: 2008/3/5 3:00
|||\ 81 KPB310 /|||
Subject Poster Date
     The oil smoke`n blues datsonovic 2008/2/29 5:24
       Re: The oil smoke blues A14force 2008/2/29 9:02
         Re: The oil smoke blues datsonovic 2008/2/29 9:10
           Re: The oil smoke blues ddgonzal 2008/2/29 17:47
             Re: The oil smoke blues A14force 2008/2/29 19:52
             Re: The oil smoke blues datsonovic 2008/3/1 0:42
               Re: The oil smoke blues ddgonzal 2008/3/1 6:32
                 Re: The oil smoke blues A14force 2008/3/1 7:48
                   Re: The oil smoke blues Dodgeman 2008/3/1 11:39
                     Re: The oil smoke blues datsonovic 2008/3/3 4:45
                       Re: The oil smoke blues Anonymous 2008/3/3 5:15
                         Re: The oil smoke blues Tyrie 2008/3/3 5:25
                           Re: The oil smoke blues datsonovic 2008/3/3 5:37
                             Re: The oil smoke blues Tyrie 2008/3/3 5:41
                               Re: The oil smoke blues datsonovic 2008/3/3 5:52
                                 Re: The oil smoke blues Dodgeman 2008/3/3 6:42
                                   Re: The oil smoke blues datsonovic 2008/3/3 7:18
                                     Re: The oil smoke blues datsonovic 2008/3/3 7:25
                                       Re: The oil smoke blues datsonovic 2008/3/3 8:47
                                       Re: The oil smoke blues Dodgeman 2008/3/3 9:13
                                         Re: The oil smoke blues datsonovic 2008/3/3 9:30
                                           Re: The oil smoke blues Ronald 2008/3/3 10:49
                                             Re: The oil smoke blues Dodgeman 2008/3/3 10:55
                                             Re: The oil smoke blues datsonovic 2008/3/3 11:07
                                               Re: The oil smoke blues ddgonzal 2008/3/3 18:31
                                                 Re: The oil smoke blues B210sleeper 2008/3/3 23:18
                                                   Re: The oil smoke blues Anonymous 2008/3/3 23:50
                                                     Re: The oil smoke blues B210sleeper 2008/3/4 0:29
                                                 Re: The oil smoke blues nzdatman 2008/3/4 4:30
                                                   Re: The oil smoke blues A14force 2008/3/4 5:43
                                                     Re: The oil smoke blues Ronald 2008/3/4 8:40
                                                       Re: The oil smoke blues bert 2008/3/4 10:18
                                                         Re: The oil smoke blues Dodgeman 2008/3/4 14:03
                                                           Re: The oil smoke blues datsonovic 2008/3/5 2:49
                                                             Re: The oil smoke blues B210sleeper 2008/3/5 3:00
                                                               Re: The oil smoke blues datsonovic 2008/3/5 3:07
        Re: The oil smoke blues Anonymous 2008/3/5 3:51
        Re: The oil smoke blues datsonovic 2008/3/5 4:46
