Re: !!a15 TURBO!!
Not too shy to talk
From Geelong
hi, i've ran an l series (same princable though) with a blow through system scince 2001 with a sc14 s/c. the teflon has held up at 10psi. i use the car for burnout comp's so it get's really hot. also i run twin webber's that came off a factory blow through turbo masarati. you'll need to use a rising rate fuel reg and keep your fuel presure about 4-5 psi above your boost presure.
Posted on: 2008/7/26 0:14
Re: !!a15 TURBO!!
Not too shy to talk
From Geelong
oh by the way the rising rate reg that i have, i actually made my self. all it is is a holly blue reg with the adjuster screw drilled out and a peice of tube silver soldered to the end of the screw. because it is about 1square inch, when it see's 1psi of boost it give's you 1 more psi of fuel preasure. it work,s well!!
Posted on: 2008/7/26 0:24
Re: !!a15 TURBO!!
From Lethbridge, AB, Canada
I am building an A12 turbo setup with an SU turbo carb and turbo from an MG Metro .. same engine as the mini but turbo 1.3l
Should be getting very close to being finished by the end of summer.
Posted on: 2008/7/26 0:45
'73 Datsun 1200 Sedan Turbo A12
Re: !!a15 TURBO!!
From sydney
would i use a carter black electric high pressure fuel pump????
Posted on: 2008/7/29 11:30
TYR-33D (SLEEPA)
Some is good,
More is better
And too much is just enough
Stroked is nice but id'e rather be Blown
Re: !!a15 TURBO!!
From sydney
and what fuel pressure regulator would i use??
Posted on: 2008/7/29 12:04
TYR-33D (SLEEPA)
Some is good,
More is better
Re: !!a15 TURBO!!
From Christchurch NZ
How much fuel pressure does that supply at idle, or cruise throttle? Do you run your TB before or after the supercharger?
Posted on: 2008/7/30 6:54
Forced Induction!
Re: !!a15 TURBO!!
From sydney
any one????????????????????
Posted on: 2008/8/5 11:10
TYR-33D (SLEEPA)
Some is good,
More is better
Re: !!a15 TURBO!!
From newcastle, NSW
Go for a good Quality one, like a malpassi rising rate, got mine on the weekend off a mate for cheap, buy a new one from a repratable dealer and you can't go wrong!
Posted on: 2008/8/5 11:14
Re: !!a15 TURBO!!
From sydney
wat would i hav to ask for??
Posted on: 2008/8/5 11:22
TYR-33D (SLEEPA)
Some is good,
More is better
Re: !!a15 TURBO!!
From newcastle, NSW
Ask for a Malpassi rising rate fuel regulator, might be a bit pricey but you get what you pay for, they might have some other brands depend on where you go, just ask around for a good quality fuel reg
Posted on: 2008/8/5 11:25
« 1 2 3 4 (5) 6 7 »
