Re: once again the s13 disk conversion
Quite a regular
From Kedah, Malaysia.
i'm doing this conversion right now using disc hub, need to machine down my hub today to fit the disc..
Posted on: 2008/8/29 22:46
From Brisvegas, oz
well i have now found that the drum hub does not fit perfectly, you still need to grind or lathe of about 1 mm of meat but this time in a different area
Posted on: 2008/8/29 23:19
www.camerasplus.com.au
From Brisvegas, oz
aaaah crap. ive done the conversion and there is now almost no brakes, ive bleed it twice and its no better. did i have to upgrade the master cylinder aswell? what size do i need?
Posted on: 2008/8/30 6:03
From The garage, NZ
master cylinder on my wagon was fine. Heaps of brakes. Everything tight? maybe the seals have had it??
Posted on: 2008/8/30 6:26
From Brisvegas, oz
what size was the master on it, just the 11/16
Posted on: 2008/8/30 6:27
From The garage, NZ
standard wagon cylinder. Should be same as sedan etc
Posted on: 2008/8/30 6:40
From Radelaide, South Australia
whats the part number for a standard rda replacement (s13) rotor for this swap.?
Cheers, Dane.
Posted on: 2008/8/30 6:43
Boost.. boost.. BOOST!!! Gotta love Lag...
* 76 coupe, twin 40mm a12, project...
* 79 ute ca18det, track/street...
* 84 FJ45 landcruiser project...
* 88 D21 navara 4x4, sr20de vvt daily...
From SYDNEY,NSW
are these s13 sr clipers and disks or ca18 calipers and disk brakes?
also are wreckers the best place to pick these up?
Posted on: 2008/8/30 8:00
vouch points for PIGDOG J-Dat dats-me TRAV 40RST minitruckin 120fly DEMO 1200dat aidaniel matty discobob mick1200 cemax DATSKOOL - all have helped me out with parts...Thankyou
From Brisvegas, oz
you can use either, i have used the slotted ca18det ones.
Posted on: 2008/8/30 9:12
From Christchurch NZ
The best place to get them is off the silvia forums. Most of the silvia guys go for the big five stud brake conversions. They almost give away their old stuff, 'cos it's of no use to them........
I got my rotors and calipers (with almost new pads) for $20!
Posted on: 2008/8/30 21:28
Forced Induction!
« 1 (2) 3 4 »
