Re: A completely different A-series build!
From NZ
Compression ratio - I agree with the very high compression ratio approach for this project. Say 15:1 if you can actually achieve it. As has already been stated with small throttle/openings the effective comp Pressure will be comparable to say 9 or 10:1. I reckon this will be the biggest single improvement but you'll have to be disciplined not to use full throttle or risk severe detonation. High octane pump fuel.
Carb - small (1" ~ 1.25") SU type carb as these are very fuel efficient.
Exhaust - extractors, wrapped for heat retention/gas speed, and with std bore outlet (not 2" as this will be too large to maintain gas speed at low rpm/low throttle openings.
Camshaft - std cam (if not an even milder design).
Head - round port head with the most efficient high swirl combustion chamber design (maybe A12 roundport head?).
Hot air - I'm not entirely convinced on the hot air for economy vs cold air for power theory but it would be easy to experiment with this once the rest of the engine is set up.
Posted on: 2008/8/31 10:36
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
Subject Poster Date
     A completely different A-series build! blownb310 2008/8/29 3:06
       Re: A completely different A-series build! Anonymous 2008/8/29 3:10
         Re: A completely different A-series build! Dodgeman 2008/8/29 3:49
           Re: A completely different A-series build! Rallytwit 2008/8/29 3:57
             Re: A completely different A-series build! PIGDOG 2008/8/29 4:11
               Re: A completely different A-series build! 1000Coupe 2008/8/29 5:31
                 Re: A completely different A-series build! Dodgeman 2008/8/29 13:42
                   Re: A completely different A-series build! beattie 2008/8/29 14:26
                     Re: A completely different A-series build! Dodgeman 2008/8/29 14:46
                       Re: A completely different A-series build! blownb310 2008/8/29 15:18
                         Re: A completely different A-series build! Dodgeman 2008/8/29 15:45
                           Re: A completely different A-series build! blownb310 2008/8/29 16:01
                             Re: A completely different A-series build! Dodgeman 2008/8/29 16:06
                               Re: A completely different A-series build! kelmo 2008/8/29 19:33
                                 Re: A completely different A-series build! blownb310 2008/8/29 20:28
                                   Re: A completely different A-series build! blownb310 2008/8/30 13:42
                                     Re: A completely different A-series build! Anonymous 2008/8/30 14:00
                                       Re: A completely different A-series build! blownb310 2008/8/30 14:14
                                       Re: A completely different A-series build! supafatto 2008/8/30 14:15
                                         Re: A completely different A-series build! kelmo 2008/8/30 21:20
                               Re: A completely different A-series build! Fandatstick 2008/8/31 10:36
                                 Re: A completely different A-series build! Dodgeman 2008/8/31 15:32
                                   Re: A completely different A-series build! blownb310 2008/9/1 3:41
                                     Re: A completely different A-series build! 1000Coupe 2008/9/2 4:35
       Re: A completely different A-series build! ddgonzal 2008/8/29 6:23
         Re: A completely different A-series build! cheater_5 2008/8/29 7:04
         Re: A completely different A-series build! Sumith 2009/4/21 8:54
           Re: A completely different A-series build! ddgonzal 2009/4/21 17:50
           Re: A completely different A-series build! blownb310 2009/4/22 2:37
             Re: A completely different A-series build! LONGBROW 2009/4/23 4:01
               Re: A completely different A-series build! 1000Coupe 2009/4/23 4:22
             Re: A completely different A-series build! Sumith 2009/4/24 9:10
               Re: A completely different A-series build! ddgonzal 2009/4/25 6:47
                 Re: A completely different A-series build! blownb310 2009/4/30 3:30
                   Re: A completely different A-series build! ddgonzal 2009/4/30 6:35
                   Re: A completely different A-series build! B2Slow 2009/5/2 7:32
                     Re: A completely different A-series build! blownb310 2009/5/28 2:09
                   Re: A completely different A-series build! blownb310 2009/5/28 2:01
                     Re: A completely different A-series build! ddgonzal 2009/5/28 5:03
                       Re: A completely different A-series build! blownb310 2009/5/29 0:21
                         Re: A completely different A-series build! ddgonzal 2009/5/30 6:22
                           Re: A completely different A-series build! blownb310 2009/6/15 18:58
                             Re: A completely different A-series build! ddgonzal 2009/6/17 6:19
                               Re: A completely different A-series build! blownb310 2009/6/18 3:26
                                 Re: A completely different A-series build! ddgonzal 2009/6/18 4:36
                       Re: A completely different A-series build! Dodgeman 2009/7/18 18:34
       Re: A completely different A-series build! sikyne 2008/8/31 1:24
         Re: A completely different A-series build! D 2008/8/31 4:35
           Re: A completely different A-series build! dazza1200 2008/8/31 4:52
           Re: A completely different A-series build! Dodgeman 2008/8/31 5:27
             Re: A completely different A-series build! Dodgeman 2008/9/13 12:00
               Re: A completely different A-series build! blownb310 2008/9/28 4:05
                 Re: A completely different A-series build! blownb310 2008/10/4 3:17
                   Re: A completely different A-series build! Dundee1000 2008/10/4 4:30
                     Re: A completely different A-series build! Mildman 2008/10/4 4:33
                       Re: A new A-series mpg record? blownb310 2008/10/9 2:55
                         Re: A new A-series mpg record? Ianey 2008/10/9 3:59
                           Re: A new A-series mpg record? wolki101 2008/10/9 4:06
                             Re: A new A-series mpg record? LittleFireyOne 2008/10/10 1:42
                               Re: A new A-series mpg record? blownb310 2008/10/10 13:31
                                 Re: A new A-series mpg record? Dodgeman 2008/10/14 3:33
                                   Re: A new A-series mpg record? blownb310 2008/10/14 3:46
                                     Re: A new A-series mpg record? ROConnor 2008/10/14 7:30
                                       Re: A new A-series mpg record? Dodgeman 2008/10/14 9:31
                                 Re: A new A-series mpg record? Fandatstick 2008/10/16 10:27
                                   Re: A new A-series mpg record? Dodgeman 2008/10/16 10:56
                                     Re: A new A-series mpg record? ROConnor 2008/10/16 11:24
                                     Re: A new A-series mpg record? Fandatstick 2008/10/18 14:00
                                       Re: A new A-series mpg record? blownb310 2008/10/25 0:37
                                         Re: A new A-series mpg record? Rallytwit 2008/10/25 3:02
                                           Re: A new A-series mpg record? Dodgeman 2008/10/25 3:44
                                             Re: A new A-series mpg record? blownb310 2008/10/25 3:57
                                               Re: A new A-series mpg record? Dodgeman 2008/10/25 5:11
                                                 Re: A new A-series mpg record? ROConnor 2008/10/25 7:36
                                                   Re: A new A-series mpg record? blownb310 2008/10/25 14:47
                                                     Re: A new A-series mpg record? Datsunitus 2008/10/25 16:19
                                                       Re: A new A-series mpg record? blownb310 2008/10/25 16:23
                                                         Re: A new A-series mpg record? Datsunitus 2008/10/25 16:25
                                                           Re: A new A-series mpg record? blownb310 2008/10/25 16:26
                                                       Re: A new A-series mpg record? Gary_P 2008/10/25 16:37
                                                         Re: A new A-series mpg record? Datsunitus 2008/10/25 17:15
                                                           Re: A new A-series mpg record? Gary_P 2008/10/25 19:41
                                                     Re: A new A-series mpg record? Dodgeman 2008/10/26 1:00
                                                       Re: A new A-series mpg record? D 2008/10/26 1:50
                                                         Re: A new A-series mpg record? ROConnor 2008/10/26 6:30
                                                           Re: A new A-series mpg record? D 2008/10/27 13:58
                                                       Re: A new A-series mpg record? blownb310 2008/10/27 19:37
                                                         Re: A new A-series mpg record? femtnmax 2008/12/1 3:28
                                                           Re: A new A-series mpg record? blownb310 2008/12/1 3:47
                                                             Re: A new A-series mpg record? femtnmax 2008/12/6 3:45
                                                               Re: A new A-series mpg record? blownb310 2008/12/6 4:19
        Re: A new A-series mpg record? femtnmax 2008/12/7 2:32
        Re: A new A-series mpg record? blownb310 2008/12/7 15:00
        Re: A new A-series mpg record? femtnmax 2008/12/8 3:05
        Re: A new A-series mpg record? ddgonzal 2008/12/13 11:07
        Re: A completely different A-series build! blownb310 2009/4/20 16:13
        Re: A completely different A-series build! Gary_P 2009/4/20 17:19
        Re: A completely different A-series build! blownb310 2009/4/21 3:42
        Re: A completely different A-series build! ddgonzal 2009/4/21 5:42
                           Re: A new A-series mpg record? Fandatstick 2008/10/14 2:49
                             Re: A new A-series mpg record? blownb310 2008/10/14 3:13
       Re: A completely different A-series build! pager 2008/9/1 4:05
         Re: A completely different A-series build! D 2008/9/2 4:03
           Re: A completely different A-series build! Dodgeman 2008/9/2 10:18
             Re: A completely different A-series build! reuby_tuesday 2008/9/2 11:49
               Re: A completely different A-series build! Dundee1000 2008/9/2 12:39
                 Re: A completely different A-series build! reuby_tuesday 2008/9/2 12:56
             Re: A completely different A-series build! blownb310 2008/9/2 12:58
               Re: A completely different A-series build! dazza1200 2008/9/3 13:19
                 Re: A completely different A-series build! blownb310 2008/9/3 22:27
                   Re: A completely different A-series build! Dodgeman 2008/9/4 0:21
                     Re: A completely different A-series build! blownb310 2008/9/4 1:30
                     Re: A completely different A-series build! blownb310 2008/9/4 1:35
                       Re: A completely different A-series build! Dodgeman 2008/9/4 2:53
                         Re: A completely different A-series build! racinaround 2008/9/4 4:05
                           Re: A completely different A-series build! blownb310 2008/9/4 4:28
                             Re: A completely different A-series build! blownb310 2008/9/4 4:33
                         Re: A completely different A-series build! Gary_P 2008/9/4 4:39
                           Re: A completely different A-series build! blownb310 2008/9/11 1:58
                             Re: A completely different A-series build! Fandatstick 2008/9/13 11:35
       Re: A completely different A-series build! DaveB 2008/9/2 5:12
         Re: A completely different A-series build! pager 2008/9/2 6:28
       Re: A completely different A-series build! LONGBROW 2009/4/24 1:54
       Re: A completely different A-series build! blownb310 2009/7/18 3:16
       Re: A completely different A-series build! blownb310 2009/7/20 13:08
       Re: A completely different A-series build! superbin 2009/7/20 14:48
         Re: A completely different A-series build! ddgonzal 2009/7/20 18:08
       Re: A completely different A-series build! billybuilt 2009/7/20 21:07
         Re: A completely different A-series build! ddgonzal 2009/7/21 0:51
         Re: A completely different A-series build! D 2009/7/21 0:57
       Re: A completely different A-series build! jmac 2009/7/21 10:52
         Re: A completely different A-series build! D 2009/7/21 11:10
           Re: A completely different A-series build! Dodgeman 2009/7/21 16:42
             Re: A completely different A-series build! ddgonzal 2009/7/21 17:18
           Re: A completely different A-series build! D 2009/7/23 2:41
             Re: A completely different A-series build! ddgonzal 2009/7/23 4:17
               Re: A completely different A-series build! D 2009/7/23 5:06
               Re: A completely different A-series build! blownb310 2009/7/29 3:53
       Re: A completely different A-series build! superbin 2009/7/23 7:40
       Re: A completely different A-series build! benny 2009/7/23 7:50
       Re: A completely different A-series build! blownb310 2009/7/29 3:48
         Re: A completely different A-series build! Dodgeman 2009/7/29 17:34
           Re: A completely different A-series build! blownb310 2009/7/30 2:34
           Re: A completely different A-series build! D 2009/7/30 2:36
             Re: A completely different A-series build! 1000Coupe 2009/7/30 3:53
       Re: A completely different A-series build! jmac 2009/7/29 4:35
       Re: A completely different A-series build! blownb310 2009/8/2 20:19
         Re: A completely different A-series build! ddgonzal 2009/8/3 0:54
           Re: A completely different A-series build! blownb310 2009/8/3 3:02
             Re: A completely different A-series build! Dodgeman 2009/8/5 15:53
       Re: A completely different A-series build! ang94541 2009/8/6 1:35
         Re: A completely different A-series build! blownb310 2009/8/10 18:49
       Re: A completely different A-series build! D 2009/8/6 5:09
         Re: A completely different A-series build! blownb310 2009/8/10 18:51
           Re: A completely different A-series build! ddgonzal 2009/8/12 7:01
             Re: A completely different A-series build! blownb310 2009/8/14 19:29
       Re: A completely different A-series build! superbin 2009/8/14 19:45
         Re: A completely different A-series build! D 2009/8/15 0:13
       Re: A completely different A-series build! blownb310 2009/8/15 4:44
       Re: A completely different A-series build! blownb310 2009/8/15 4:50
       Re: A completely different A-series build! blownb310 2009/8/16 2:19
       Re: A completely different A-series build! blownb310 2009/8/18 2:49
       Re: A completely different A-series build! 1000Coupe 2009/8/18 3:03
         Re: A completely different A-series build! D 2009/8/18 6:08
           Re: A completely different A-series build! blownb310 2009/8/21 17:59
             Re: A completely different A-series build! ang94541 2009/8/25 5:37
               Another new record! blownb310 2009/8/28 0:30
                 Re: A completely different A-series build! D 2009/8/28 0:59
                   Re: A completely different A-series build! ddgonzal 2009/8/28 6:54
                     Re: A completely different A-series build! blownb310 2009/8/28 15:55
                       Re: A completely different A-series build! D 2009/8/29 2:26
                       Re: A completely different A-series build! ddgonzal 2009/8/29 5:57
                         Re: A completely different A-series build! Rallytwit 2009/8/29 6:24
                           Re: A completely different A-series build! ROConnor 2009/8/29 6:28
                             Re: A completely different A-series build! blownb310 2009/9/5 21:56
                       Re: A completely different A-series build! Dodgeman 2009/8/31 14:53
                         Re: A completely different A-series build! blownb310 2009/9/5 22:01
                           Re: A completely different A-series build! Fandatstick 2009/9/6 10:31
                             Re: A completely different A-series build! blownb310 2009/9/6 21:29
                               Re: A completely different A-series build! Dodgeman 2009/10/19 6:56
                       Re: A completely different A-series build! ang94541 2009/9/1 4:42
       Re: A completely different A-series build! superbin 2009/8/28 7:24
       Re: A completely different A-series build! 1000Coupe 2009/10/20 2:56
         Re: A completely different A-series build! ddgonzal 2009/10/20 3:47
           Re: A completely different A-series build! 1000Coupe 2009/10/20 4:58
           Re: A completely different A-series build! Dodgeman 2009/10/21 17:40
       Re: A completely different A-series build! lamb_daiquiri 2011/6/4 0:59
       Re: A completely different A-series build! blownb310 2011/6/5 3:22
       Re: A completely different A-series build! ddgonzal 2011/6/5 3:56
