Re: F/S Datsun 1000 disk brake upgrade kits
From Melbourne vic
i would be interested in buying the modified parts only.
Posted on: 2008/9/3 8:54
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
From Coondle, WA Australia
just a quick one
how big are the sigma disks that you are using in the kit?
Depending on how big they are, I might get a set off you too.
Since i have skyline brakes on the back, which are 260mm from memory, and the lazer ones are only 200mm it means i have to play around with bais. If the sigma ones are closer in size, then they may be a better option for me than the lazer setup
Posted on: 2008/9/8 13:55
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
The Laser ones that were available through Neil are ventilated rotors while the Smigma ones are solid if that makes any difference to you.
With the low weight of the B10 cars I doubt that you would ever worry the Smigma ones with heat buildup, but just something to be aware of.
Posted on: 2008/9/8 14:10
Love your Datsun.
Treat it well.
« 1 (2)
