Help! re-assembling 5 speed, advice needed
From melbourne VIC
I'm in the process of reassembling a 60 series dogleg 5 speed (FS5W60L) and require as much info as possible.
Does anyone have a copy of a FS5W60L transmission manual?
Could anyone tell me if there is meant to be any clearance between the main bearing in the s/plate and the two thrust washers (spacers) either side?
I'm under the impression that there should be no clearance, can anyone else confirm?
Cheers
Posted on: 2008/9/23 6:04
Re: Help! re-assembling 5 speed, advice needed
From Christchurch NZ
PM me your email, and I can send you a manual for an H pattern 60 series box. Not 100% same, but the principles are the same.
Posted on: 2008/9/23 10:49
Forced Induction!
From melbourne VIC
someone must have experience with assembling a 60 series dogleg box!
does anyone know if the main shaft needs to be pressed back into the main bearing until there is no clearence between the thrust washer?
cheers
Posted on: 2008/9/23 13:58
From Melbourne vic
dude pm revhead001 he'll know
Posted on: 2008/9/23 14:10
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
Did someone say my name? My revvy super senses were tingling.
I'm suprised that you didn't ring. I'll come over and give you a hand Nick.
Although be warned, I'm a little crook and if I stifle a cough A booger the size of a golf ball shoots out the schnoz!
Posted on: 2008/9/23 21:58
dont worry about the booger, its the other end you have to worry about.
Posted on: 2008/9/23 22:52
From SE Melbourne
Posted on: 2008/9/24 0:43
Mildman, Datsunless
Is there one for a 60L? I guess it is really only the gear layout and the different selector forks that are different.
Posted on: 2008/9/24 1:06
