datsun a15 head no
hi guys im an old fart and slow on the keys so it mite take a while to answer questions and so on. any way i have a sunny with a 1500 in it i took the rocko cover off to check the part no the head and it is H89IorT on it the other numbers are 615 can anybody tell me what it means. i have a 1400 with H75 on the head cheers
chris
Posted on: 2009/1/10 10:14
Re: datsun a15 head no
From Christchurch NZ
The H89 head is an A15 head.
Posted on: 2009/1/10 10:27
Forced Induction!
H89 is used on A14 and A15 engines. It is a B310 (1978-1982 Sunny) code.
Posted on: 2009/1/10 18:10
depends where in the world you are. The A14's I've seen here have had H75 (Or 72?)
Posted on: 2009/1/10 20:20
Forced Induction!
Yes, indeed. Depends on where in the world you are. But with so many "used Japan import engines" sent all over the world, some care may be taken with identifying parts.
H72 is a common A14 cylinder head, it was originally a B210 part number but also fitted to some B310 cars. H89 is a B310 part number, and the H89 head was used in both A14 and A15 engines. For more information on what the "Hxx" type codes mean, see Nissan 'Applied Model' codes
Perhaps the most important thing for newbies to realize is that A15 parts (except for the crank/pistons) are not necessarily any "bigger" than A14 parts. A15 and A14 are nearly identical, the most important difference is the A15 has 7% more displacement, hence more performance all else being equal. It can also rev as high an as A14, albeit with slightly more wear at high revs due to the longer stroke.
Posted on: 2009/1/10 21:05
From Melbourne vic
The one question i have not seen answered
is whats the difference between
h89 & h891? I have one of each and the
only physical difference is the h89 has had
the manifold water jacket blocked, but this
could have been done by anyone.
Posted on: 2009/1/11 1:11
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
Not too shy to talk
From croydon vic
I HAVE 2 A15s 1 HEAD IS H89. 1 IS H891 LOOKING A THE ENG No THE H89 IS A FARE BIT OLDER MABY H891 IS FOR UNLEDDED PETROL. H75 IS LOW COMP OPEN CHAMBER
Posted on: 2009/1/11 13:23
All Datsun A-series heads since 1974 are specifically made for unleaded. And all the 1200 ones will work fine with unleaded.
Take pics of face, top and both sides and post them here. We'll help you analyze the differences.
Posted on: 2009/1/11 23:56
From gold coast QLD.
Dodgy must still be on holidays,poor old DD is coping a real workout lately
Posted on: 2009/1/12 0:18
He's probably driving his Datsuns. I only get to talk about them...
Posted on: 2009/1/12 0:32
