Re: aussie datto1200 2 door
From Perth WA AUS
Ahh, looking good already. You should have seen the state of my 2Dr when I got it, rust, rust & more rust, also chassis damage repaired at the lowest cost!
You have a good starting point, can't wait to so it finished! might motivate me some more.
Posted on: 2009/2/16 10:29
Datsun 1200 2Dr sedan.
From Adelaide, Australia
need some more help. panel work is not my forte. any advice? im not sure im on the rite track. the lower 1/4's were rusted out and i have welded new metal back in. also near the tail lights was a little wavey so ive taped out what i could and filled in the rest. there was alos a dent which i couldnt really reach from the inside so ive filled that too. it wasnt deep but was bigger than i first suspected.
Posted on: 2009/2/25 1:26
From Armidale N.S.W
With filler Work a lot of it with 120 on an orbital it will take a little longer but you will get a better result. When its starting to get feathered out go to 120 or even 180 on a block, This is all dry sanding to. We stay away from wet work till the final block down for paint. For the lines and any grooves etc wrap a bit of paper around a round piece of wood like a broom handle but thicker. To get lines mask the high side and low side then get some cheap matt black pressure packs and paint the lines in then you just sand up to the lines with the piece of round timber or even plastic pvc pipe etc. then just run over the lot quickly a few times so to lose any sharp edges if any.Hope this helps. Your doin well mate keep it up ay it will be worth it.
Posted on: 2009/2/25 4:27
73 1200 wagon SOLD
From Perth WA AUS
Yeah just like DatsAndy said, sometimes when I think I am happy with my repairs I spray a good coat of primer on it & let it dry, then have a really good look at it into the light. I find that it shows up all the crap that I missed (only sprayed 3 cars so far).
Posted on: 2009/2/27 10:12
From Perth WA AUS
Any more pic dude?
Posted on: 2009/3/12 8:49
Re: datto1200 2 door sedan
just an update. im thinking of racing this. never raced b4 but always wanted to so today i bought a motor for the 1200. paid $200 for a SR20DE wid computer and loom...BARGAIN!.. now i just have to dummy it up into the car. only panels left is 1 rear 1/4 and im half way through the 2 doors then all will be in primer :) hopefully
Posted on: 2009/4/25 5:01
« 1 (2)
