1200/120y struts and coilovers
From australia tasmania
hey guys,
im making up coil overs for my Toyota customers,
thought you datto fells maybe interested in them too?
soo can people give me some info,
i want to know what 120y strut diameter is and what the standard shock length is.
also i know quite a few people upgrade to stanza struts for the brake upgrade. if someone has the same info on these as well that would be good.
thanks
Aaron
Shakotan Garage
Posted on: 2009/4/11 3:59
old skool cool...
www.shakotangarage.com
Re: 1200/120y struts and coilovers
From SYDNEY,NSW
im interested, ill be getting buying some soon so get back to me on prices etc...
will they include the springs?
i have 1200 drum struts so ill look at measurements for you.
Posted on: 2009/4/11 6:59
vouch points for PIGDOG J-Dat dats-me TRAV 40RST minitruckin 120fly DEMO 1200dat aidaniel matty discobob mick1200 cemax DATSKOOL - all have helped me out with parts...Thankyou
stanza are 51mm od, ans most threaded sleaves are 51mm id or 52mm is so great fitment there. 200b strats same. dont know 120y
Posted on: 2009/4/11 8:28
From cranbourne, vic
45mm od, i cant remember exactly but i think its 640mm over all with a 416mm body. i just put them in my drum struts to get me by untill i go disc, so i cant be sure.
im going to use 81 pulsar shocks (monroe pn:25-3436) ,over all - 551mm and body lenth 334mm with 10mm less travel and same 37od body.. im using 51mm coil over sleeves, with a sleeve over the 120y made from 40nb 2.5mm wall tube (you need to cut it length ways and open it up then slide it over) and then welded that to the strut. i cut the strut down too 360mm from the top to the bottom where it bolts to the steering arm.
Posted on: 2009/4/11 9:44
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
From northern 'burbs adelaide
120y struts are 51mm OD ... just did a set on my ute and if i had extra cash i would have put coilovers on it as a 51mm kit is avaliable
Posted on: 2009/4/11 15:14
id be up for a set for my 200b struts or stanza
ta nick
Posted on: 2009/4/12 14:24
Car free
hhmm,
thanks for the info guys.
ill be putting up a add in the FS section soon. depending on how much interest may keep a pair of struts in stock and do an exchange system with out other coilovers. could also convert your own struts to coilover and send them back to you..
thanks
Aaron
Posted on: 2009/4/14 5:38
old skool cool...
From Adelaide
120y are only 45 OD lol
aid ur smoking crack when u measure
Posted on: 2009/4/14 9:04
maybe dpends on what type of 120y ones, there seem to be jap and aus types, maybe one is 45 and other 51, or maybe he just has different struts already
Posted on: 2009/4/14 9:07
From Adelaide
nope all 120y are 45od
Posted on: 2009/4/14 9:10
