Re: i need help with an engine carby combo that will sound rorty and old!!
From Auckland N.Z
another way to get that 'chunky' sound is get the lightest flywheel you can. heavy flywheels smooth the engine rotations which is nice but wont sound like the wua...wua...wua noise you want. that with the lumpy cam and nice carb/filter and it will sound mint. it will also go good as well
Posted on: 2003/8/13 11:56
From Sydney, Australia
im thinkin im guna stay old skool, definately an a-series motor first with webers and different cam. should sound reeeeeel nice cant wait
Posted on: 2003/8/13 12:05
Lumpy cams have "less driveability" because they make less HP than the stock cam at low rpms ... and with the corresponding big valves, intake and exhaust, you lose power at low rpms. Tall tires on the back make this even worse. However if done right, it's all outweighed by more HP at high rpms.
One thing to do is get a bigger engine (A14/A15) with a lumpy cam, so you still have as much HP as the A12 even at low rpms.
Datsa73's engine sounded real good (in the photo album). It is A15 with lumpy cam, dual downdraft webers and maybe 2" exhaust with a "glass pack" (straight through) muffler. A little loud, but sounded good at all rpms. It "howls" at 7-8000 rpm. At idle it sounds a little like the choke is stuck on, but muscular sounding.
Posted on: 2003/8/13 20:45
yeh im guna stick with an a15, ive already sourced a cheap one off this dude i know:D.
ddgonzal u say that it howls at 7 - 8000 rpm? i didnt think those motors could rev that high. does the lumpy cam change the characteristics of the motor so much that u can rev them higher than normal?
that makes my idea even better! i love cars that can rev, being an ex corolla 4age master lol:P.
Posted on: 2003/8/14 0:59
From Little Rock, AR
I've got a mild cam in my A15, but it sounds good with head work, Dellorto's, headers, and 2 1/4" exhaust with turbo muffler. I used to have a straight through "glasspack" muffler and it definitely sounded nice and throaty, but I got pulled over a lot and my ears rang after long drives. To get the best of both worlds, I put a Flowtech Race Ready exhaust cutout before the muffler so whenever I want that loud obnoxious race car sound, I just uncap the cutout. Mine only revs to 7200 rpm though, but pulls hard from 3000. I'm still trying to figure out "metric" cams, I'm used to lift and duration in inches. I was thinking of a heftier cam from Matsuoka, but I like mine.
Posted on: 2003/8/14 3:04
From Christchurch, New Zealand
Its a combination of things that let them rev more, you need head work such as stronger/double valve springs and possibly bottom end work as well to make them stand up to those revs. You also need a hotter cam though as if you build a motor to pull those revs and leave the std cam in it itll make its peak power at 5000rpm or some equally low number so there will be no point in using the extra revs.
Ive heard of plenty of A series running 8krpm+. All it takes is money.
The smaller A12 A13 etc is better if you want to pull high revs as its got a shorter stroke
HTH
Posted on: 2003/8/14 3:34
From Brisbane
mikila i am not sure on the power output i am gettting but it is pretty good , it is going on a dyno soon and will post results
speaking of Aseries reving Feral errol has a A13 that revs to 10200rpm , it has had serious work done to it, i think he has taken it apart and using the head on a A15 i think check it out on www.datrats.com.au link A13
i have heard of Aseries reving to 11000rpm and over but i have never seen reving that hard!!
Posted on: 2003/8/14 4:21
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
awesome... so how much does it cost to get the cam installed not including head work and not including the cost of the cam??
great b120, it will be interesting to see how much power u make out of ur webers. by the way, have you done any other work to it? how much did the webers cost you?? new??
thanks
mik.
Posted on: 2003/8/14 8:49
that would be a sight to see... an a series revving to 11000 rpm on a dyno... would sound awesome
Posted on: 2003/8/14 8:50
From Brisbane
i bought the webers for $650 in pretty good condition with Gx manifold, braided lines and filters . The engine has had work yep, got a street cam, its a14 rebuilt, bored out, the head is a12GX (recoed) ported and flowed and a few extra goodies in there too
Posted on: 2003/8/14 9:56
« 1 (2) 3 »
