Re: just a few questions on datsun 1000's
From Perth WA
wise words
Posted on: 2009/10/22 4:19
datsun 1000, Its not the size its how u use it.
From gold coast QLD.
I'll second those wise words unless you plan on winning the pools,while i think of it,put your location in your account so we know where your at,i'm guessing se qld. as i think your new ride came from Millmerrin??
Posted on: 2009/10/22 4:52
Quite a regular
From rockhampton qld
can u pm me a phone no. if you interested
Posted on: 2009/10/26 14:21
Quite a regular
From Caboolture, South-East Queensland
Yeah youre right bert, it was a bloody long drive to get it too, about 4-5 hours either direction but still well worth the effort, i sold the back seats and standard sunvisor for 200 same day i got it home so that was very good as now the car effectively cost me only 200, i was even allowed to borrow my old employers work truck to pick it up, so fuel was free, gotta love that word, free, now im just curious as to what offset ill need on 7inch wide wheels to avoid contacting the inner guards and suspesion parts, i do plan to flare if needed but i have to go 15inch wheels to clear the brakes that ive got for it, once again with the magical free word because a mate of mine has an r32 with standard gts brakes and hes upgraded to the gtst type m brakes this weekend, so ive got a full set of discs calipers and hubs, and to top it off they are the same 4stud pattern as the little 1k came out with, just a trip to a machining shop to get caliper brackets made up and then a hunt for a suitable maste cylinder and the old girl with pull up faster than if i hit a wall.
once again pointers and comments welcome, thanks for the heads up on the rover v8s, damn you wiki(shakes fist angrily at the internet) i think itll end up receiving a nice little 12a mild port with a small turbo just for kicks, all this is about 3 years down the track as im still on my red p plates and as such cant drive a modified car. ive got some 15's here to check clearances on the brakes when i get them later today so expect a post later on tonight with the verdict on whether or not i may be able to squeeze a set of 14's on her instead (not a fan of giant wheels so we will see how it goes).
thanks again James
Posted on: 2009/11/1 2:42
I have a drinking problem... two hands and only 1 mouth
From Perth
You won't fit those brakes under 14's
Nor will you fit those brakes on a 1000 without serious mods
I used to run 13x6.5 on the rear of my coupe with 0 offset
The fronts were 13x6 with +6 offset
Even then they needed the lower of the front guard trimmed to allow it to steer
And the guard lips needed rolling and pumped out
I only ran 185/60/13 tyres
So 15's should be fun for you to fit
My wagon runs 14's with 195's and same deal as far as mods... plus the bigger tyre diameter the more chance of them rubbing on the footwell area also
You can do 15's... but they need to be spot on offset and tyre size
Posted on: 2009/11/1 5:52
Quite a regular
thanks for that its a big help, im after either 195 or 205 tyres all round and i plan on doing guard work and that sort of thing before i give it a lick of paint, and as for not gettin the brakes on the 1k im always up for a good challange so ill let you guys know how it goes and hopefully ill have my phone fixed and be able to post up plenty of pictures for ya.\
still waiting on the brakes to arrive so ill let you know, also just to reiterate they are from a gts not a gtst and are actually quite small, very much so for a car of that size but i believe just right for what i want them for so i think ill see how it goes and get geared up for some serious cutting and welding to get the buggers on there.
thanks again James
Posted on: 2009/11/1 6:56
« 1 (2)
