ca18 1200 coupe project
Quite a regular
hey there, im thinking about selling my 1200 coupe project! i have had this car for 3 years and dont have anywhere near enough time to finisg it. the body has been taken back to bare metal and all rust and dints repaired, this was done by proffesional pannelbeaters. all badge holes have been welded up, and the body is in primer, it has been under a car cover in a shed eversince the bodywork was done around 8 months ago. it has disc brake front end with lowered king springs, standard diff with 2" lowering blocks. a ca18det and 5 speed gearbos has been fitted with custom crosmembers, the motor has even compression across all cylinders with maximum 10psi diffrence, it has a stainless exhaust manifold with a t28bb turbo and braided oil lines, adjustable cam gears and gates racing timing belt. the wiring harness has been modified by kev rowley to plug straight in, and has standard computer. the 5 speed gearbos is fitted with a short shifter. has hole cut in floor where a trans tunnel will need to be welded in. a 450x300x76 front mount intercooler has been fitted with polished and blue silicone hoses.
also comes with:
*brand new s13 alloy radiator
*r31 skyline diff (not cut)
*brand new headlights
*brand new indicators (front and side)
*maddat accelerator cable
*maddat speedo cable
*maddat steering box brace
*brand new power windows kit
*fibreglass dash, door trims, kick pannels
*all original parts that came out of car when it was stripped
*all nuts and bolts are in seperate bags labled where they come from for easy assembly
car doesnt have bonnet or grill!
make me an offer i cant refuse, i dont really want to sell it but it has to go!
jpg  PB200187.jpg (34.52 KB)
10864_4b401579eef5f.jpg 448X336 px
jpg  datto side.jpg (43.42 KB)
10864_4b4015a1d61c9.jpg 448X336 px
jpg  PB200185.jpg (29.84 KB)
10864_4b40160a26dda.jpg 448X336 px
Posted on: 2010/1/3 3:59
Re: ca18 1200 coupe project
From mandurah
i would of bought this beast but i just bought a coupe yesterday
Posted on: 2010/1/3 4:04
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From sydney
What sort of cash you looking at ?
Posted on: 2010/1/3 5:12
PROJECT:DATSUN sunny sedan CA18det
Quite a regular
around 5grand
Posted on: 2010/1/3 5:35
Quite a regular
bump
Posted on: 2010/1/5 8:07
From mandurah
hey the second picture of this coupe ism the same picture as the one in the ROTARY COUPE thread
Posted on: 2010/1/5 9:38
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Tamworth , NSW
it is the same coupe.
Posted on: 2010/1/5 9:48
Quite a regular
yer same car, used to have a 12a in it.
Posted on: 2010/1/5 10:04
From Tamworth , NSW
did you fit the 6 speed?
Posted on: 2010/1/5 10:07
Quite a regular
yep then pulled it all out and sold it all!
Posted on: 2010/1/5 10:44
