Re: GYLEZY'S 1200 coupe, project two
From SA
today i got the new bucket seats into the coupe, im not sure might need to move them closer together...
but ill see how they go, thanx to Andy for poopping round aye!!
cheers
Dan
Posted on: 2009/9/29 13:11
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
From SA
ok well the plans have changed a bit, iv got a 1500 to pick up off of jennadat, and a t25 sitting on my bench. iv changed my mind because iv seen andy-roos 1000 ute, that thing has a A15T and man it is a quick little car.
so i will begin to make up some manifolds for a blow through, i plan to use a 180 holley... if anyone is interested in some turbo manifolds for a blow through setup i will be making some up, for a standard inlet manifold on a oval port head with a t25 flange on it... just shoot me a pm or reply to the thread im more than happy to make a few up just looking for numbers......
cheers
Dan
Posted on: 2009/11/10 23:12
Go Hard Or Go Home
From south coast nsw
yep a15t good #OOPS#. im keen on a minifold if you get the numbers.
Posted on: 2009/11/10 23:41
From Brisbane
I'd be keen on a manifold aswell
Posted on: 2009/11/11 0:51
From Melbourne, Australia
I would suggest strongly considering going with injection straight off the bat instead of blow through carby to suit the turbo A15
i spent a lot of money getting all the right fuel system and timing and everything right for a carb setup, but at the end of the day i went injection and spent the same money over again converting
Posted on: 2009/11/11 1:42
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Adelaide
I agree with 1200rallycar about the injection, I have been there and done it years ago. I spent alot of time with different carbys. I could get them working well, with ok drivability, good power and avarage fuel consumption. Changed over to a basic aftermarket ecu, and never looked back, a little more power, heaps better drivability and fuel consumption.
If you include dyno time the injection, they will cost about the same and is a lot easier to modify a ECU if you change anything on your engine.
Coupe looks great.
Scott
Posted on: 2009/11/11 1:56
From pooraka,,adelaide
yes thats the same with me but then i decided if i go injection i'll just go ca down the track but i thind he likes the idea of cerb not inj. . .
edit; im pretty sure davo is keen on a manifold
and i'll give u a call later dan about that trailer..
Posted on: 2009/11/11 1:59
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
From northern 'burbs adelaide
hey man are you gonna get the flanges yourself or do you still want me to get them made? i was gonna send the laser cutting off this week so just give me a call
Posted on: 2009/11/11 4:53
From SA
made a fair bit of progress over the past 3 days.
for those interested this priject will be moving pretty quickly over the next few months...
any way, i pulled the motor out, and bagan removing rusty sill pannels,
here are the pics:
cheers
Dan
Posted on: 2010/1/11 10:58
Go Hard Or Go Home
you should see toms new one ... already completely stripped
Posted on: 2010/1/11 11:40
« 1 2 3 4 (5) 6 »
