do 7inch wide rims fit a 1200 ute>?
From Brisbane
theres some sick ssr's that i want but theyre 7inch wide they use a 195 tyre which is what i have on my trxs n they fit my ute but yeh anyone know? cheers
Posted on: 2010/2/2 12:48
Re: do 7inch wide rims fit a 1200 ute>?
From mandurah
yeah they will fit i have 6.5 on my ute and there is heaps of room at the back dunno bout the front though it would be tight ,but would depend on offset
Posted on: 2010/2/2 13:02
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Brisbane
i think its +2 offset
Posted on: 2010/2/2 13:19
From mandurah
i say suck it and see if it fits them get them :)
Posted on: 2010/2/2 13:40
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Geelong
haha are ya looking at the ones on ebay? i've got the same in 15x6.5 and i've had to go pretty narrow tyres on the front, otherwise the catch the guards and bend em. offset is +15 and im not sure about tyre size, my brother has fleeced my rims for now haha.
Posted on: 2010/2/2 14:07
I have 7" wide wheels on my ute, front and back.
More important than the wheel width is the tire size. Mine are only 175 on the front (could fit 185 if the offset was better) and 195 on the back (could fit at least 205s if the offset was optimum).
Posted on: 2010/2/3 4:32
From mandurah
hey dd do the 175s look stretched on those rims
Posted on: 2010/2/3 4:36
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
yes, what is there other than stretched?
175 tires are designed for 4.5" to 6" wide wheel.
Posted on: 2010/2/3 5:02
From Adelaide, Australia
I had +4 6.5's on my 1200 with standard offset hubs etc. I needed to pump the guards and trim the front edge off the guard but I had +5° castor, -3° camber. These had 185's a-drive yokos. Backs fitted OK, you'd be right
Posted on: 2010/2/3 6:28
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
17x7 235/45/17 fitted on my ute
so did 15x7 205 50 15
Posted on: 2010/2/3 9:54
1200 ute unfinish'd sr20 $$$
1200 ute stocko
bumble bee drift pig
XR8 tow car / daily
bailz is orsum
