ARP bolts kit part numbers
From Gold Coast, Australia
hi there guys, looking for the parts numbers of the conrod bolts and main bolts that ARP offer for the A15, i already have the head stud part number - 202 4203 thanks too rally1200. let me know guys please.
Cheers Pierre
Posted on: 2009/5/16 0:30
Re: ARP bolts kit part numbers
Pierre,
Pretty sure 102-6002 is the con rod bolt kit.
Not sure on the main bolts, I know they have BMC A Series Main Studs: 206-5401
But someone will have to confirm if they are in fact identical to Nissan A series (I reckon they are).
Cheers
Posted on: 2009/5/16 0:47
From Vancouver, Wa
Head 202-4203
Rod 102-6002
Mains 202-5401a
Hope this helps.
Posted on: 2009/5/16 5:32
1969 Datsun 1000 (B10)
1972 Datsun 1200 coupe (ADVAN)
1981 Datsun 210(B310) 4-door (sr20det)
1971 Datsun 1200 (sedan)
exactly what i wanted too know guys thank you very much.
Posted on: 2009/5/16 5:43
what about flywheel bolts?
Posted on: 2009/5/20 9:53
Edited by 2QK4U on 2010/2/24 3:16:59
Posted on: 2010/2/24 3:18
Does ARP make flywheel bolts?
Posted on: 2010/2/24 3:58
From Adelaide, Australia
The older motors are imperial, later motors are metric. I have heard of toyota 2TG bolts being used but not sure as I can't find the thread.
Posted on: 2010/2/24 4:56
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
The stock Datsun flywheel bolts are good. Just torque them correctly and use thread locker if going above 7500 RPM.
Posted on: 2010/2/24 4:59
Thread is 10x1.25... on the late model motors, not sure if you can find an ARP bolt in that size. I would run NEW factory bolts, loctite and also look at getting the thing dowelled if you have any more concerns, there is play in the bolts and the flywheel iis actually clamped on the head of the bolt not on the shank of the bolt, 3 4mm dowels 120° apart should do the job, the end of the crank is soft unlike the journals and easy to drill.
Posted on: 2010/2/24 5:15
IPRA Build
