EOI H89 recon head.
From Perth WA AUS
As above, Unused since reco dont need it so make an offer.
Located in Perth WA, will post at your expense.
Pics if req'd.
Posted on: 2010/3/24 13:03
Datsun 1200 2Dr sedan.
Re: EOI H89 recon head.
From Perth
Pics and specs
Posted on: 2010/3/24 13:19
From Freo
BIG and Hi COmp...:P
Posted on: 2010/3/24 13:21
A15 PSI Project Motor
'72 CB750k,
From mandurah
how much levey ,do you have new valves for it ?
Posted on: 2010/3/24 13:37
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth WA AUS
Valves are good, name your price.
Posted on: 2010/3/25 12:12
Hey Levey,
My head needs re-work but it also needs a fat gasket to bring the comp-ratio down. So it basically needs more money thrown at it.
I'm interested in this one but not certain, I have a low comp head on the way to me to try but I would prefer high compression.
Any chance you could tell me how big the chambers are in cc's?
Is the rocker gear included? Springs singles or doubles?
Posted on: 2010/3/26 2:47
To get the cc's I use a cheap CD case covers with a small drilled hole and 10ML syringe to inject oil, simply count the cc's until you can see the chambers are full of oil (any oil is good).
You may need to seal around the chambers with some coloured (marine?) grease just to make it easy to see when it is full and to make sure no oil leaks out.
I think I need 21cc+ chambers to put me back onto pump fuel.
EDIT: Oh, could you also confirm if the ports are standard or larger?
Posted on: 2010/3/26 2:51
Combustion chamber is 25cc stock.
Posted on: 2010/3/26 3:50
From Perth WA AUS
I CC'd it a while ago but cant remember the result, will do it again.
Some pics:
jpg  10112009(002).JPG (29.77 KB)
9665_4bac646d81d60.jpg 480X360 px
jpg  H891 1.JPG (68.28 KB)
9665_4bac647b8c254.jpg 720X540 px
jpg  H891 3.JPG (82.93 KB)
9665_4bac648d651f6.jpg 720X540 px
jpg  H891 4.JPG (29.13 KB)
9665_4bac6497d0433.jpg 480X360 px
jpg  H891 5.JPG (28.08 KB)
9665_4bac64a114980.jpg 480X360 px
Posted on: 2010/3/26 7:39
From Perth WA AUS
I remember now, I got 27.5cc last time and the same reading on a H75 head. This time 28cc, are you sure about the 25cc DD? this head has been resurfaced aswell.
Oh and I used water not oil.
Ports:
Inlet: 33x40mm
Ex: 22x29mm
EDIT: Comes with single springs and rocker gear.
Posted on: 2010/3/26 8:02
Edited by levey on 2010/3/26 8:18:16
(1) 2 3 »
