Re: heads (painful veiwing)
From windsor, sydney
I have heard of that in the past as well but dont think it would be achievable. there are too many water channels and internal webs to weld successfully . and with the availability of cnc porting machines becoming more common its probably easier to go that way with a standard head. But if you want to go all out why not do some research on motorcycle heads and see if you can match the bore spacing with say a suzuki huabusa twin cam head and mount that on a aseries block , that would be a good project!
Posted on: 2010/6/5 11:45
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
Subject Poster Date
     heads (painful veiwing) bige 2010/6/3 1:01
       Re: heads (painful veiwing) clyons8 2010/6/3 1:42
         Re: heads (painful veiwing) D 2010/6/3 3:43
         Re: heads (painful veiwing) ddgonzal 2010/6/3 3:45
           Re: heads (painful veiwing) clyons8 2010/6/3 3:53
       Re: heads (painful veiwing) bige 2010/6/3 4:05
       Re: heads (painful veiwing) greenapple 2010/6/3 5:48
       Re: heads (painful veiwing) bige 2010/6/3 6:00
         Re: heads (painful veiwing) ROConnor 2010/6/3 9:01
       Re: heads (painful veiwing) bige 2010/6/3 9:05
         Re: heads (painful veiwing) ROConnor 2010/6/3 9:41
       Re: heads (painful veiwing) D 2010/6/4 6:01
       Re: heads (painful veiwing) thedevilshands 2010/6/4 6:43
       Re: heads (painful veiwing) D 2010/6/4 12:23
         Re: heads (painful veiwing) wards 2010/6/5 10:57
           Re: heads (painful veiwing) wards 2010/6/5 11:06
             Re: heads (painful veiwing) D 2010/6/5 11:11
             Re: heads (painful veiwing) wards 2010/6/5 11:16
       Re: heads (painful veiwing) clyons8 2010/6/5 11:20
         Re: heads (painful veiwing) clyons8 2010/6/5 11:22
       Re: heads (painful veiwing) A14force 2010/6/5 11:29
         Re: heads (painful veiwing) wards 2010/6/5 11:45
       Re: heads (painful veiwing) bige 2010/6/5 11:45
       Re: heads (painful veiwing) estyre 2010/6/5 12:03
       Re: heads (painful veiwing) pepper 2010/6/5 12:36
       Re: heads (painful veiwing) D 2010/6/5 14:10
         Re: heads (painful veiwing) clyons8 2010/6/5 15:14
       Re: heads (painful veiwing) D 2010/6/5 16:23
