Re: 5 Speed adaptors? Which gearbox to use?
There is also the alfa boxes but these boxes are quite rare now
while the T5 from a Ford ute with a 6 cylinder is only 34kg and
gearsets are often from Mustang v8s in the early Word class boxes.
ratios are pretty good if not excellent!!!
2.95, 1.95, 1.34, 1, 0.73 (also .65 overdrive available!)
Posted on: 2010/6/14 5:41
Subject Poster Date
     5 Speed adaptors? Which gearbox to use? sikyne 2010/5/7 14:21
       Re: 5 Speed adaptors? Which gearbox to use? dattoman_1000 2010/5/7 15:56
         Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/7 16:23
           Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/8 3:40
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/8 0:32
       Re: 5 Speed adaptors? Which gearbox to use? Lemonhead 2010/5/8 2:19
         Re: 5 Speed adaptors? Which gearbox to use? DATTOWHORE 2010/5/8 2:32
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/8 4:08
         Re: 5 Speed adaptors? Which gearbox to use? ZigZag 2010/5/8 7:48
           Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/8 9:15
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/8 13:46
         Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/8 14:23
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/8 23:22
         Re: 5 Speed adaptors? Which gearbox to use? PIGDOG 2010/5/9 0:41
       Re: 5 Speed adaptors? Which gearbox to use? Lemonhead 2010/5/9 0:48
         Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/9 2:07
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/9 7:16
       Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/9 15:12
       Re: 5 Speed adaptors? Which gearbox to use? DattoFrog 2010/5/10 0:30
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/10 1:05
         Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/10 2:18
       Re: 5 Speed adaptors? Which gearbox to use? Lemonhead 2010/5/10 3:02
         Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/10 6:25
           Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/10 14:53
             Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/11 8:38
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/10 6:29
       Re: 5 Speed adaptors? Which gearbox to use? denuto 2010/5/11 8:56
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/11 12:47
         Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/11 14:34
           Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/12 1:37
             Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/12 2:14
               Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/12 2:25
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/12 1:11
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/12 3:02
         Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/12 4:13
           Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/12 13:29
             Re: 5 Speed adaptors? Which gearbox to use? tommo73 2010/5/12 14:22
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/12 5:04
       Re: 5 Speed adaptors? Which gearbox to use? thedevilshands 2010/5/12 5:24
       Re: 5 Speed adaptors? Which gearbox to use? PIGDOG 2010/5/12 9:15
       Re: 5 Speed adaptors? Which gearbox to use? jmac 2010/5/12 15:16
         Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/13 0:12
           Re: 5 Speed adaptors? Which gearbox to use? 1200rallycar 2010/5/13 1:10
           Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/13 11:39
             Re: 5 Speed adaptors? Which gearbox to use? PIGDOG 2010/5/13 12:09
       Re: 5 Speed adaptors? Which gearbox to use? PIGDOG 2010/5/13 2:31
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/13 5:12
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/13 12:31
         Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/13 12:39
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/13 12:45
       Re: 5 Speed adaptors? Which gearbox to use? jmac 2010/5/13 15:40
         Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/18 13:52
           Re: 5 Speed adaptors? Which gearbox to use? PIGDOG 2010/5/19 0:23
             Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/19 3:53
       Re: 5 Speed adaptors? Which gearbox to use? PIGDOG 2010/5/14 9:48
       Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/14 12:29
       Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/18 2:06
       Re: 5 Speed adaptors? Which gearbox to use? TUF-110 2010/5/18 2:40
         Re: 5 Speed adaptors? Which gearbox to use? sikyne 2010/5/18 6:08
           Re: 5 Speed adaptors? Which gearbox to use? PIGDOG 2010/5/18 6:30
       Re: 5 Speed adaptors? Which gearbox to use? LittleFireyOne 2010/5/19 8:22
       Re: 5 Speed adaptors? Which gearbox to use? D 2010/5/19 14:28
       Re: 5 Speed adaptors? Which gearbox to use? jmac 2010/5/19 14:47
         Re: 5 Speed adaptors? Which gearbox to use? LittleFireyOne 2010/5/19 15:25
       Re: 5 Speed adaptors? Which gearbox to use? ssskiwi 2010/6/12 8:06
       Re: 5 Speed adaptors? Which gearbox to use? D 2010/6/14 5:41
