Re: A12/A14/A15 Ajustable cam pully/ Vernier pully
From Christchurch NZ
There is a cheaper way of altering your cam timing. Turn your cam sprocket around half a turn, and then dial in your cam using a degree wheel and DTI.
Once your timing is where it needs to be, drill a new dowel hole in the end of you camshaft, and tap the cam dowel back into the new hole. It's not adjustable, (Although I did once do a multi hole adjustable cam sprocket, but the engine died a horrible death before I got the chance to tinker with the timing.
Posted on: 2010/7/20 9:40
Forced Induction!
Subject Poster Date
     A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/19 10:25
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully clyons8 2010/7/19 10:29
         Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/19 10:38
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully bige 2010/7/19 10:52
         Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/19 11:45
           Re: A12/A14/A15 Ajustable cam pully/ Vernier pully dattoman_1000 2010/7/19 12:06
             Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/19 12:25
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully racetech 2010/7/19 12:39
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully clyons8 2010/7/19 12:44
         Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/20 6:43
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully bige 2010/7/20 6:58
         Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/20 7:06
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully bige 2010/7/20 7:48
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully A14force 2010/7/20 9:40
         Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/21 7:24
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully A15_Tweaker 2010/7/21 9:38
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Rezlo 2010/7/21 19:31
         Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Kiri1 2010/7/23 6:26
       Re: A12/A14/A15 Ajustable cam pully/ Vernier pully Rezlo 2010/7/23 14:21
